Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
Need the pto to work on a 6300 john deere tractor we have changed the fuses and changed the sencer on the back can you help
    President:
  • 1,627 Answers
If you have tried a new sensor and a new switch the the next step is to replace the pto solenoid valve.If that proves fruitless then the b.c.u.needs to be replaced or bypassed.The solenoid valve will cure your problem 90% of the time.If that does not work,let me know,i can tell you how to by-pass the b.c.u..
Posted on May 08, 2010
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Does a 1978 john deere 2130 have a 2 speed pto and how do you change speeds
Remove the clip from the pto shaft by squeezing it shut,push it in some then pull it out.Turn the shaft around and put it back in making sure the clip snaps back in place.
Nov 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Garden
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
849 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
