Question about Hunter 30124 Air Conditioner
Ac blowing hot air instead of cold
On my 2000 buick lesabre my ac is blowing hot air instead of cold air what's wrong with
  • 2 more comments
  • Anonymous Mar 27, 2008
    2000 lesabre-belt,freon switches,and compressor appear functional, freon was added to bring up low middle of gauge,still blows hot air and tired of stories, want answer. i do know gm had over 100 tech bulitins on this car, includeing air cond. please hlp
  • rick83 Mar 29, 2008
    thanks lot for the information I haven't had time to see if anyone of those solution will fix the problem I have been busi but i will let yall know again thanks
  • darlie241 Jul 15, 2008
    my 98 bonneville is ok on freon and started out intermittedly blowing out hot air. Now it is only hot air. Could it be a relay switch? Do they have fuses?
  • robotman Jul 24, 2008
    MY 2000 Buick LeSabre ALSO suddenly stopped blowing cold air(only hot) as well. Still registers charged with hose test.(gauge) I would LOVE for someone to enlighten me on his matter b4 I spend a fortune to have this fixed, if I could do it myself. I just bought this car, what a way to go.......
    Problem Solver:
  • 8 Answers
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Posted on Mar 27, 2008
  • Samuel Allen
    Samuel Allen Mar 30, 2008
    If your A\Cstill blowing hot air
    (1)Check if there is discharge pressure or high pressure from the discharge or liquid side of the compressor.
    (2)Check your suction pressure if there is suction pressure
    There should be a pressure difference on gauge check
    You should be reading a higher reading on the discharge side of the compressor, if the discharge pressure is low ,you may have compressor problem
    (3) Check the compressor engage soleniod if it is locking the pump when it energize, or for fan belt slackness.
    Let me know what works for you.
  • Samuel Allen
    Check for more possibe cause why A\C blowing hot air
    Check expansion valve or metering device for cloging
    Check for liquid dryer for restriction
I have a 98 Buick Lesabre Limited. It blows Cool air, but not Cold.And also, I can't seem to make it blow out of the Center Dash Vents.
Cornelius, vent problem could be a pinched or loose vacuum line on controller,faulty AC vacuum motor, faulty AC programmer,etc. needs to be checked out by a good Tech, diagnosed and estimate on repair.
As far as vehicle only blowing cool air, issue could be blend door issue, plugged AC condenser core dirt/debris, low AC refrigerant, plugged AC lines internal, failing compressor, etc., again should be checked out, diagnosed and estimate for repair by a good Tech.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1998 Buick Lesabre No Air From Dash Vents
http://repairpal.com/ac-vent-problem-346
Car AC Not Blowing Cold Enough Car Repair Information From MasterTechMark
My Car Is Not Cold What Could be Wrong Elite Auto Repair
Jul 15, 2016 | Buick Cars & Trucks
Driver side vents blow hot air even when ac is on
There are a number of things that could be going on. Do you get cold air out of the passenger side vents? Have you tried sending the air to the defrost vents, or the floor? Do you get cold air out of those when you do?
Apr 22, 2015 | 2003 Buick LeSabre
Why does the ac on my 2000 buick lesabre only blow cold on the passenger side?
This problem is likely due to a failed part called the blend door, this door has an electric motor drive, to replace it requires the dash be removed form the car entirely. The blend door is a door that moves back and forth between the AC core and the Heater core to provide cold hot or a blend of air flows from both cores to give the desired temperature. Other issues can cause this and due to the cost or repair a through diagnostic should be done to confirm my guess is correct about the door being the problem.
Jun 22, 2012 | 2000 Buick LeSabre
My AC blows hot air out the driver's side and cold
My 02 Century has dual temp controls . One for driver for passenger. Make sure you don't have the dual climate enabled and just set for heat on your side and AC on the passengers
Apr 04, 2010 | 2001 Buick LeSabre
2000 Buick LeSabre No heat, blows cold air.
check to see if both hoses are hot going to your heater core if they are then core is fine.That would point to your temperature sensor.
Feb 07, 2010 | 2000 Buick LeSabre
Heater blowing cold air
replace your hot to cold switch...
Jul 12, 2009 | 2000 Buick LeSabre
Air conditioning in 2000 lesaber
Vent door between the two sides isn't opening or the flex hose going between the two is off.
Jun 03, 2009 | 2000 Buick LeSabre
Buick LeSabre 2002 My heater does not produce hot air. The fan works but blows only cold air.
just one idea my freinds buick if it gets low on antifreeze it will not blow hot air maybe you can check the antifreeze level
Mar 15, 2009 | 2000 Buick LeSabre
Dual heat and ac system
broken cable? if possible trace the cables back to the box move then bolth and see if one doesnt, if so you could alwase manually move it for a temp fix
Jul 01, 2008 | 1993 Buick LeSabre
Hunter 30124 Air Conditioner Logo
778 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
