Question about Kenmore 73952 Gas Dryer
Can you use copper gas line to hook up a gas dryer
  • 10,865 Answers
The building code standard for gas is black steel pipe. Joe
Posted on May 03, 2010
  • 409 Answers
Yes copper is fine to hook up your dryer, just use flare fittings, not compression fittings, this is to guard against leaks.
Just bought a used frigidaire crown series gas dryer need a hook up line in the back to connect the gas. Is it a certain size i need or how do i find out
The line size depends on three things...the BTU of the burner and the length of the line...and the types of gas..Natural or LP
To find the line size you nees a chart that gives you the sizing based on these factors...
Here is a chart for Natural gas and I'm sure LP is also in thei site if you need that...
http://www.engineeringtoolbox.com/natural-gas-pipe-sizing-d_826.html
heatman101
Oct 04, 2010 | Frigidaire FGQ332ES Gas Dryer
How do you get into the dryer to change the natural gas connector to a propane connection?
Not sure what country you are in, so I am unsure that the same conditions apply.
The gasline from the meter must be interrupted. Propane bottles connection pipe can then be brazed to the copper line . By law a propane regulator must be fitted between the bottle and the gqas line going to the dryer.
This must be fitted by a licensed gas fitter ( plumber) so if any problems occur your insurance will pay out on fire or other faults.
Placing the propane bottle line directly to the dryer without a regulator and inside a building is dangerous and unlawful, as most dryers are not vented correctly to deal with propane.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | LG DLE5955 Dryer
I HAVE A AMANA FULL CAPACITY 7.1 DRYER THAT NEEDS A FITTING THAT HOOKS ON THE BACK OF THE DRYER INTO THE GAS LINE
If you are talking about the adapter between the flexible gas line and your dryer, your local hardware store will have it. I usually recommend that you take your flexible gas line with you so they can match up the correct size. The dryer gas pipe is standard. Good Luck, Appliance Specialists
Jan 04, 2010 | Amana ALG331RAW Gas Dryer
How can i split an existing gas line to hook up my dryer? I HAVE A GAS LINE THAT GOES TO MY WATER HEATER AND WOULD LIKE TO SPLIT IT OFF TO HOOK MY DRYER UP BUT CANT FIND A FITTING TO DO THAT
Just put a "TEE" into the line. Make sure you use "BLACK IRON" pipe fittings on gas lines. Galvanized will create problems and you will not only have leaks in the future, galvanized pipe in gas lines is a violation of almost every building code.
Nov 22, 2009 | Kenmore Dryers
Compressor stops then leaks down to low setting
That little copper line is an unloading line, to bleed compressed air out of the compressor head so that the motor can more easily start the compressor. Pressor switch should be threadded into top of air tank, and the unloading valve is built into the side of the switch. When the tank reaches the high pressure setting the switch disconnects power to the motor and opens the unloading valve at the same time. The unloading valve should be connected to the compressor discharge line through a check valve with an unloading valve port upstream of the check valve. These valves are usually threaded into the top of the air tank as well. Sounds to me like your valve was leaking and someone bypassed it.
Sep 14, 2009 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Whirlpool gas dryer
check new gas line for foreign objects
May 06, 2009 | Whirlpool LGR5634L Gas Dryer
Gas Smell emitted from Gas Dryer only when dryer is running
check the gas line to burner, must be there if it only happening when unit is on
Mar 20, 2009 | Kenmore 74842 Gas Dryer
Whirlpool Imperial seventy dryer does not heat up
If there is a copper line feeding gas to it, PULL THE DRYER WAY FROM THE WALL AND TURN THE GAS OFF AT THE VALVE IMMEDIATELY!
Natural gas and copper do not mix, and the copper line will corrode from the inside out.
Now, on to the problem, it's very likely the timer has failed IF it does not rotate all the way through the drying cycle. If it does, and the clothes do not heat up, then reply back what you are experiencing and I will give you move help.
Jan 24, 2009 | Dryers
I have a gas dryer that I need to hook up. Previously there was an electric dryer there. So I need to know what to do to be able to hook up my new gas dryer.
unit will work on 120 volts instead of 240, vent will work from old dryer 4 inch in size the gas hook up is where you need the gas company to come and run the gas lines and regulator and the tank for the gas
Apr 23, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
271 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
