Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Need to reset the lamp timer
Put in a new lamp, but do not have the paperwork with it, now I don't know how to reset the lamp timer, and everytime I turn on the tv, there is a pop up screen telling me to reset the lamp timer
  • donnaj515 May 06, 2010
    I guess I messed up, i need to reset the timer lamp for panasonic model pt52lcx35 the solution I got was for a different model that had pip, mine does not
1 turn tv on
2 press vol- on tv and pip on remote at the same time for more than 5 sec a message will appear
Posted on May 06, 2010
The old lamp in my in focus LS 110 reached its maximum hours. I replaced with a new lamp but it is not firing up - i think I need to reset the lamp hours but don't know how and don't have the...
Sorry, I am not familiar with the Infocus LS 110 but the user guide can be downloaded at
http://www.retrevo.com/support/InFocus-LS110-Projectors-manual/id/1081dj697/t/2/
You don't need to put in your email address but you will need to type in the numbers. It come in a PDF format so you will need adobie acrobat to read the file. It should have instructions on how to reset the lamp hours.
Hope this helps
Aug 01, 2011 | InFocus LS 110 Multimedia Projector
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
PUT IN A NEW LAMP BUT NEED TO KNOW HOW TO RESET TIMER. THE WORDS STAY ON THE SCREEN FOR 1 MINUTE.
Turn the TV on, and once the timer leaves the screen (after 1 minute as you say) you do the following.
Hold both the "Volume Down" button on the TV it's self and the "Split" button on the remote for at least 5 seconds. That should reset the timer.
Jan 21, 2011 | Panasonic PT-44LCX65 Television
How do i reset the timer
go to the menu, find lamp settings then select, lamp counter resit. confirm.
Oct 22, 2009 | Sanyo PLC XU50 Multimedia Projector
RESET LAMP TIMER ON PT-61LCX65
Google the exact model number and you should find the information on the internet for free.
Aug 07, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Need to reset lamp hours for KDF-E55A20
This model does not require lamp timer reset, put new lamp securely and power up TV for picture.
Jun 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
The lamp on The Infocus X1 projector at my work is burned out and i need to replace it, but do not want to attempt to without knowing how first can some one give me a guide on how to do this?
very simple. remove the lamp door on the left side (looking from the front) using a flat head screwdriver. unplug the plug, and unscrew the 2 screws. pull the lamp out. put the new one in and reverse the instructions. piece of cake!
Apr 02, 2009 | InFocus X1 Multimedia Projector
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
412 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
