Hi I have a westinghouse lvm-42w2 and I am scrollig through my recorded programs and suddenly the screen splits right down the middle, so the left side is a negative effect and the right is in full color. When there is no signal input the scree is white on the left and black on the right. Can any one please help thanks karl
  • buffyz Mar 26, 2008
    Thanks but I tried all that buffyz
    thanks I will contact them although I did call the support center and they were less than helpful buffyz
    Genius:
  • 1,226 Answers
Hello!
Please refer to the manual on resetting the setting of view. anyway did you try unplugging and replugging from the wall outlet. There should be a reset setting to go back to the original or factory setting. melnavz
Posted on Mar 26, 2008
  • Emelio Navaja
    Emelio Navaja Mar 26, 2008
    However if this not work then maybe you can contact the vendor of your tv to let repair the setting.
  • Emelio Navaja
    Emelio Navaja Mar 31, 2008
    Bring your TV to the service center not just contacting them because they can hardly troubleshoot by phone.
  • 813 Answers
Here is link for your tv support call in support center
http://www.westinghousedigital.com/contactus.aspx
just submit the from
contect no :- 1 (866) 287-5555 for supppot
    Master:
  • 351 Answers
Dear Karl,
My suggestion is just contact to Authorised service Engg, to fix this problem ,i think this problem is related to calibration. for more details ,please read this document.
http://www.audioholics.com/reviews/televisions/flat-panels/westinghouse-lvm-42w2/lvm-42w2-remote-calibration-benchmark-tests
Takecare
Westinghouse tv to fix mod #lvm-42W2 .Does anyone have a schematic diagram for this TV .The fault is top half of the screen is blurred and the bottom half good in the presence of picture .Thanks WA.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 12, 2015 | Westinghouse Televison & Video
White spots tv screen
Bright and dark spots on screen might be due to the fault of the screen itself. In some cases, it will be reparable. Contact any service technician, because, if it is a repairable fault, the panel might need to disassemble.
May 24, 2013 | Westinghouse LVM-42w2 Television
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
LVM-37w1 after 5 minutes of viewing, picture and sound go off. Blue power light turns orange. attempts to turn on TV are unsuccessful. Blue light immediately turns orange.
I saw this fix posted on another blog by a fellow named Patrick. I tried it today and it it worked. It fixed my Westinghouse lvm-37w1. Basically disassemble the back of the TV (removing all the screws on the edges and middle). Remove screws holding bottom speaker and stand. There are 2 chrome rods extending down. There are small screws inside holding them on. You can turn the rods and unscrew the screws but need a small screw driver to put them back on. Remove the black cover on the back. remove the plates on the lower middle section. You will expose a printed circuit card. unplug wires and unscrew 4 screws holding it in. Remove it, turn it upside down and inspect the solder joints near the lower middle (especially under the gray relay on the other side). I found 4 solder joints that were cracked. Resolder the larger solder joints that are cracked or look bad (small solder joints are too delicate). Put it back to gether and it should work now. Mine works great. No more black screen with no sound.12_2_2011_5_11_21_am.jpg
Sep 29, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
I think I set up my Westinghouse VR-6025Z incorrectly, but I cannot get back to the Setup Wizard to change it. I have power cycled after setting to factory defaults and still can't get the SW to show...
Hello Jdreier520, I would be more than happy to assist you but would rather do it live. Please send me an email to westytech@westinghousedigital.com so I can better assist you. You can either provide me with a contact # or I can send you my contact information so you can call me at your earliest convenience. Please note I will need model #, serial #, and TW# all located on the back of the TV as well as what you have connected to the TV and how they are connected. Looking forward to helping you get your TV running in no time.
Jun 20, 2011 | Westinghouse LVM-42w2 Television
Resolution Difficulties
If you are using cable and a cable box or a satellite box, the setting must be done on those. The TV only reproduces 720p because that is what the incomming signal to it is.
Nov 30, 2007 | Televison & Video
LVM-37w1 37inch LCD HDTV
It is worth fixing but you have to replace the power supply. It is a fairly common problem with the Westinghouse units.
Aug 14, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
