Question about Intel Motherboard
845gvsr motherboard problem
Hi
one 845 gvsr motherboard gives a fatal error message when I install any griver any device.I tried a lot but culdnt find solution. Where actually the problem is? I checked RAM, CPU, SMPS still the problem continues.
    Problem Solver:
  • 5 Answers
I think it is ram's malfunction. Plug out the ram chips. clean it's terminals with soft clean cloth.
Posted on Mar 30, 2008
Core voltage problems in 845gvsr
check the +12V supply(between yellow wire and black wire) at the 4 pin power plug connector for the CPU.
If there is no voltage then you will have to change the power supply(SMPS). Thanks
Mar 19, 2010 | Intel D845GVSR Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Intel 845 GVSR drivers for windows vista
Hello!
Your chipset drivers are available from intel here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065
Please select your operating system and hit "Go!"
Feb 17, 2009 | Computers & Internet
Usb driver for intel 845 GVSR motherboard
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
Oct 08, 2017 | Microsoft Windows XP Professional With...
Error E9 on 845 gvsr
i have a 845gvsr mother board power not coming led is binking but not powered coming. what is the soution......
Jun 26, 2008 | Intel D845GVSR Motherboard
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
Intel 845gvsr problem
you change RAM and install correct FrequencyRAM,
Mar 16, 2008 | Intel Motherboard
845gvsr motherboard dead
near by ram slot 10 ohm registance serial smd register check
some one register bank fail{beetween cpu and ram slot}
Mar 07, 2008 | Intel Motherboard
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
Feb 24, 2008 | Intel D845GVSR Motherboard
Intel Motherboard Logo
111 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
