Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
The steering just went out on my crastman 42" riding mower. The steering arm seems to have slipped off the ball joint. Is there a part or something that holds it on the ball other than a rubber sleeve? Please advise on how to fix. Thanks!
  • 409 Answers
You have to replace the rod end, it is not repairable. Go to your local sears store, or sears parts direct.com
Posted on May 03, 2010
Lost a part that holds the ball joint together for remote steering of the minn Kota 2hp electric motor... I now have the bracket held to the steering piston with baling wire.
I used a ball joint from a riding mower steering arm to fix mine. Make sure thread size is compatible or maybe find an adapter at a MTD dealer
Sep 04, 2017 | Minn Kota Boating
One front wheel is toed out how do I adjust it
If you mean it feels like it's dragging, then you likely need to replace the lower ball joint. there is no adjustment. If you have a failing Ball joint, the wheel may buckle under the vehicle while you are driving, causing damage to the wheel, the car and possibly worse. You will want to have this checked out at a shop ASAP, or if you have a jack, jack the wheel up by the jack point ( not the suspension ) and take a pry bar and try to move the lower control arm away from the steering knuckle. If they can be separated at all, that ball joint is worn and needs to be replaced.
Sep 26, 2014 | John Deere L100 Series
Where are the grease points on a pajero
Look at the ball joints top and bottom--- tail shafts u-joints and shaft slip joints---steering ball joints and idler arm pivot point---moving shafts and arms on the transfer case . If it is a late model it probably won't have any.
Mar 23, 2013 | Lincoln 1242 Cordless Grease Gun Kit
The rod on my John Deere tractor fell off that makes it steer...how do I fix it ?
sounds like the ball joint on the steering link is worn and dropped out some models have replaceable ball joints and some you must replace the entire steering rod in either case check all ball joints for wear and replace as they are worn as well
Oct 25, 2012 | John Deere Garden
The steering arm came off the steering ball and rubber sleeve. Is there nothing else holding the arm on than the sleeve.
Probably not. If yours unscrews from the steering rod, get a replacement joint at the hardware store, Sears or at the other big box store. If yours was line mine at the job, you will have to order a new steering rod (not the official name) from Sears. If you are handy and have the tools, you can cut off the old and thread or weld on a replacement.
What happens? They wear - the ball wears and the spring looses some of its tension.
Jul 27, 2011 | Craftsman Garden
Was mowing the lawn when all of the sudden i heard a pop and the steering went on the mower. The steering wheel just spins and the rod underneath the engine is just hanging
There is probably a ball joint connection that broke, or something could have just came loose. Not a hard repair, if you are not mechanically inclined, any mower shop can fix it, or if you have a neighbor that works on cars etc can fix it easily.
Apr 24, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Turning rod keeps slipping off
Replace the bolt with a new bolt. Sounds like the bolt is not tighting down enough to make the joint tight like it should be
Feb 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
818 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
