Question about E-Machines eMachines Desktop PC
All sounds in my computer sound like they are in an echo chamber
  • 524 Answers
Thats because your sound card is actually set to sound that way. What you need to do is open your sound device manager under the control panel and then adjust the sound to your liking
Posted on May 03, 2010
When watching Netflix movie, sound sounds like is in a echo chamber. This is through a Samsung blue ray surround sound system.
You probably have the sound settings wrong for either the device that is getting Netflix movie or the Samsung sound system. You might have even got both wrong!
Dec 04, 2016 | Samsung Audio Players & Recorders
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
I have a Swisstech 15"
Hi michael_b975,
Please check the audio settings and disable the echo mode , or anything similar to that , if there is an option for default settings , please choose that option so that you would have normal sound.
May 10, 2011 | Televison & Video
Toshiba 46 HD TV-1/2 Screen going out
I have a Regza 46XV648U. And sometime my sound will sound like a Echo Chamber, i can turn it off and the sound will be alright for some time.
Aug 02, 2010 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Sounds sound like an echo chamber
1. Click Start, click Control Panel, click Hardware and Sound, and then click Sound.
2. In the Sound window right-click your Speakers and select Configure Speakers.
3. Follow the on-screen setup, and Test the available configurations.
4. Indentify whether or not one configuration appears to have less of an “echo” than others.
5. If the issue is resolved by modifying the configuration then you do not need to do anything further
May 18, 2010 | E-Machines eMachines Desktop PC
Speakers seem fine except they seem to have an echo to them
the echo is a software effect on your computer check the sound card and driver under control pannel under sound make sure reverb or echo is off it sucks
Dec 27, 2009 | Logitech X-240 Computer Speakers
My monitor internal speakers have a problem --
look in the control panel there should be something there for the sound, it should be something like a sound effect manager open it and disable it
Jul 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
Sound problem
What motherboard are you using? Does it have a Volume effects changer option on its Sound Card? Try changing that option first.
Sep 14, 2007 | JBL CREATURE II Computer Speakers
Sound problem
Sounds silly but, try muting your built in microphone, because i'l bet, the mic is picking up the sound from yours speakers and causing the echo. That's wot i've found on a few occassions. Other than that, check sound and video drivers by click Start>Run, then type in 'dxdiag' (without quotes) this will run a diagnostic on audio and video. Please rate this solution
Nov 09, 2006 | Toshiba Satellite P30 P35 Series Notebook
E-Machines eMachines Desktop PC Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
