Question about Dryers
The dryer runs but it doesn't get hot - Dryers
  • 10,319 Answers
You should read my tips on dryers not getting hot. it is very informative
Posted on May 03, 2010
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
My dryer is running hot but doesn't dry the
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Dryer runs for about 5 minutes then shuts off the clothes are hot
Your vent may be obstructed causing the dryer to trip, once it cools down it will reset itself. The way to see if thats the problem is to disconnect the vent and run the machine, if it doesn't shut off, you will need to clear the vent.
May 13, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer turns off after short period of time
It can be a lot of things. From the dryer elements getting to hot to the motor getting over heated. Try running it empty load to see if it shuts off. If it doesn't then it is the motor over heating.
May 02, 2011 | Kenmore Dryers
Dryer not putting out warm to hot air. What is the issue?
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 07, 2009 | Dryers
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
