Question about KitchenAid 24 in. KUDU02FR Built-in Dishwasher
There is water on the bottom and no power - KitchenAid 24 in. KUDU02FR Built-in Dishwasher
    President:
  • 949 Answers
It sounds like you lost power during a cycle. It is most likely the thermal fuse.
Take a look at this link I put together it will explain the places you can loose power to a dishwasher but on this model I would suspect the thermal fuse. If your model is KUDU02FR the part number for this fuse is W10258275, it looks like a small cylinder with two wires attached, it is on the control board in the upper door, removing the screws from the inner door will let you take the front panel off and expose the control.
http://www.fixya.com/support/r4689610-wont_start_or_dead_dishwasher_no
Posted on May 04, 2010
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
THE UNITS TRIPS THE POWER EVERY TIME I TURN ON THE WATER HEATER
sounds like your element is shorted out , on electric water heater heaters build up lime in the bottom and eventually the element overheats trying to heat water and burns in half, shorts out..drain water heater and kill power to it and remove your bottom element and check it out..also clean the scale out of bottom of tank with wire or something to pull it out so new element does'nt touch it when installed Good Luck!
May 16, 2011 | Garden
My Reliance water heater suddenly produced only luke warmwarm water. I checked for power to the elements. Top one had nothing, bottom one had 110. I replaced the top element (which looked ok.) (power...
Lower element will always test 120V to ground since thermostats turn off one hot wire.
Listed below are suspects in order of ease.
1) Check that hot water is not running out of TP valve and down into a drain.
This will cause water heater to run all the time but not be able to keep up.
2) Test elements before replacing anything:
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) Test electricity to water heater:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) Final thing would be full troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 29, 2010 | RELIANCE ELECTRIC WATER HEATER
No hot water
Have you checked the bottom thermostat for power coming to it and out of it. The thermostat may be bad, that would be the first thing to check. Also check the wires coming out of top thermostat to lower one for power it could be the top not suppling the power.
Jul 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have 240 volts at thermostat and conection on the tank but nothing at the bottom element. no hot water either
Thermostat may be bad and not suppling power to lower thermostat and element.
Sounds like Thermostat not working properly if no power there..
Do you have power to top element and power going into top of bottom thermostat if it has one.
May 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The water heater seems to not be heating. The bottom part of the tank is cold and the top is warm. I did reset the breaker this morning. Do I replace the bottom element?
Yes that may be the problem. To know for sure you need an electrical test meter to see if the top thermostat is sending the power down to the bottom element after the top one is satisfied.
If you have power at the bottom element and there is no power draw then you have a bad element. Drain the tank and replace it. Make sure to completely purge the air from the tank before turning thepower back on.
Heatman101
Dec 30, 2009 | General Electric GE SmartWater Household...
No power, water in bottom
it is either open fuse on the control board or loose/burnt wires in the j box at rhs bottom corner behind the toe panel.
Aug 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
I installed a now 40 gal. electric water heater, made by Reliance, problem: I have power going to the top thermostat and element, but there is no power going to the bottom element.please help, thanks Mike...
How they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank.
Apr 19, 2009 | Water Heaters
Dish drawer leaks Fisher Paykel
When water accumulates in the bottom it triggers an error code and it keeps running. There is a water sensor in the bottom. I pull out the bottom drawer, mop up the water and use a hair dryer to dry the water (the more you mop up the less you need the hair dryer). Be careful to not get any of the plastic too hot. Kill the power before messing with the unit. The first time I did this it took 20 minutes to dry out. I have gotten more proficient and it take about 5 minutes now.
I had a water leak which was due to the rinse agent cap not being completely sealed. Water leaked out of a small hole in the front (I'm guessing an air vent but don't know for sure) and flooded the bottom.
I also had a leak due to having too tall a dish in the drawer and the top not sealing. I currently have a leak on the top drawer of unknown origin, but the bottom drawer still works.
Hope this helps.
May 15, 2008 | Dishwashers
KitchenAid 24 in. KUDU02FR Built-in Dishwasher Logo
153 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
