Question about HP Pavilion a450n PC Desktop
I need to know how to clean the system and get my help and support working
I have been having troubles getting my pc system cleaned out as my computer is running slower, second i can't get my help and support to run
Nancy Montgomery
    Scholar:
  • 160 Answers
Do the following steps one by one
1.  Double click on "My Computer"
2. Select the Local Disc or "C"
3. Right click on the "C"
4. Select the Properties
5. Click on the Disk Cleanup
6. Wait for a few minutes to complete the process
7.Disk Cleanup screen appears
8. Select all the check boxes you get display
9. Select ok
10. Wait for a minute(s) to complete the process
After Completing the disk cleanup do the following
Disk Defragmentation
1. Double click on my computer
2. Select the local disk or c
3. Right click on the c
4. Select the properties
5. Properties window appears
6. Select the Tools Tab
7. Click on the defragmentation
8. Disk Defragmentation window appears
9. Select the required drive and
10. Select the "Defragmentation"
11. Wait until the process completes
Restart the system after the completation
Let me know if your problem is solved and rate me as FIXYA!
Posted on Apr 16, 2008
    Sergeant:
  • 349 Answers
Things to do if running windows.
  1. remove all programs no longer needed of the hard drive.
  2. empty recycle bin.
  3. run anti virus & anti spyware programs .
  4. www.grisoft.com has both free.
  5. download & run ccleaner also free. www.ccleaner.com
  6. delete cookies and offline file from internet explorer.
  7. defrag hard drive.
this will be a good start,let me know if you need further help.
good luck
Terry
Posted on Mar 26, 2008
  • 46 Answers
For problem #1 you should run Disk cleanup and then Disk Defragment in the Accessories/System tools folder.
For problem #2 it sounds like helps and service is stopped or the registry is corrupt. Follow this link to fix the problem:
http://windowsxp.mvps.org/helpsvc.htm
Speed up PC.-no virus/spyware,disk,
If you are determined to risk registry cleaning, you might try Wise Registry Cleaner, Glary's registry cleaner, or the registry cleaner in CCleaner or the commercial Advanced System Mechanic. You may use Revo Uninstaller to completely remove the programs you installed immediately before trouble emerged or resort to accessing the registry backup you created before cleaning. Many of the cleaners allow creation of such backups from within the software..
Sooner or later, registry cleaning seems to result in a "gotcha." You will be glad you had system restore points when that day happens. I try to leave registry junk alone, use portable apps to avoid installs affecting the registry, and make a restore point prior to every software installation.
How do you determine what is safe to clean? Well, Wise Registry Cleaner rather gives you a screen which suggests what is purportedly completely safe to remove by the screen colors indicating safe ones. If you have any doubts, don't remove the registry entry.
Not that the advice will keep you completely safe! Backup your critical data files to an external hard drive before engaging in too much registry tampering. As you chase performance, cleaning suites sound like a good option, right up to the point you crash, then you are chasing recovery options.
Use of Sandboxes and Virtual Drives avoid some garbage collection but that far more than you have requested to know about.
Adding ram sped up XP machines more than registry tweaks ever did.
Feb 13, 2015 | HP Desktop Computers - Hewlett-Packard...
Error 0xa0000001 in window
Possibly but it may be caused by many other issues.
This is from Microsofts web answer;
There are many reasons why your system may crash due to these stop errors. The most common scenarios are: Faulty drivers, Hardware issue (especially RAM) or Anti-virus software problem.
You may want to try the following and check if it helps.
Method 1:
Run Memory Diagnostics test to check for any memory problems. Refer the following link for the same.
How do I know if my computer has a memory problem?
Method 2:
Update the chipset, video card, display and network adapter drivers to the latest by visiting the computer manufacturer's website.
Update a driver for hardware that isn't working properly
Update drivers: recommended links
Method 3:
A clean boot helps to verify if any third party application services or startup item is causing this issue.
You may refer the following KB article to put the computer in clean boot:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
After the trouble shooting steps please refer to clean boot link to put the computer back to normal start up mode.
Jan 20, 2014 | HP Pavilion Computers & Internet
Why did the check engine and tcl"off"lights come on after cleaning the engine and engine compartment?
The traction control system uses the computer to work by changing engine speed.
You may have gotten water inside one of the wiring connectors or harness.
You would need to have the computer scanned for trouble codes to know what to test.
Apr 12, 2013 | 2001 Mitsubishi Diamante
Application popup: svchost.exe - Application Error : The instruction at "0x745f2780" referenced memory at "0x00000070". The memory could not be "read". Help me to rectify this...
this is a common error if you try to install a new memory card or if you are infected by a virus. if you tried to install/upgraded a new memory card. these are the thing you need to consider - memory card is not properly installed to the memory slot - memory card is not compatible to the system - if you added a new memory card it means that there is a conflict between the old and new memory card
if you did not install/upgraded a new memory card. these are the things you need to consider - you are infected by a worm/virus. try updating your system by installing system updates. install antivirus software - you might install a software that is having an issue with the memory installed in your system. - Operating system is corrupted need to reinstall the OS. - hardware failure try to check first the memory card then hard disk. or just contact local technician.
May 09, 2011 | Intel Computers & Internet
I need a cleaning manual for a coffee machine do u know were i can get one? im doing hospitality 4 and work in a cafe that has one of your machines but we do not have one on premisses.i need to do a...
I'm having trouble finding a games console that makes coffee!!
Have you searched on the web by entering the make and model number of the machine you have?
Hope this helps,
LJ
Apr 12, 2011 | Video Game Consoles & Games
Error, my computer cannot access some programs and it works very slow and get always hung.
You probably have some virus and/or malware infections. Clean up your system:
  1. Restart computer into Safe-Mode with Networking (press F5 or F8 repeatedly whilst booting)
  2. Run an online virus scan here
  3. Download, install & update Malwarebytes
  4. Run a full scan & reboot if/when asked.
  5. Clean up your system by installing and running Ccleaner
If you still have problems after cleaning up your system post back which programs you are having trouble accessing.
Nov 27, 2010 | Microsoft Windows XP Professional
I need to know how to fix the black screen on my computer
Cleaning your system unit will help solve your problem. Tools are vacuum and paint brush. After cleaning.First check for the memory or system ram. Unplug and plug it again. Same procedure with your video card. If still the same with no display, clean the memory and video card pin using hard eraser to clean the moisture or dust. If you heard 1 beep with no display that means your monitor have something wrong. Because 1 beep means good or working.
Please rate me!
Nov 24, 2010 | Computers & Internet
When i turn my computer on, it gives two long beeps, the machine is on but the screen stays blank, as though its on sleep, what do i do?
Two long beeps is the code for memory trouble. Try removing the memory modules from their sockets. Make sure the sockets are free of dust (computers can get pretty dirty inside), using compressed air (available canned from office supply places, Wal-Mart, etc.) to blow them out if needed. Make sure the contacts on the modules are clean. You can use a pencil eraser with light pressure to clean them off. Reseat the modules firmly in their sockets. Then try restarting the computer.
If the trouble continues and you have more than one memory module in the system, try replacing them one at a time and restarting the computer to try to determine which one is causing the trouble.
If the trouble still won't go away, see if you can borrow a known good memory module from someone and try that. You might have a failed system board or multiple bad memory modules. (It can happen, and can drive you nuts when you try the "one-at-a-time" trick. I've been there!)
Hope this helps!
Nov 19, 2008 | HP Computers & Internet
Acer AL1912 sometimes doesnt start
Try reseating your cable connections. While you have them off, take some compressed air and clean both the connection ports on the back of the computer and cable connections. Check to make sure there are no bent pins on the cable connectors. If you know how, you might also want to open your computer case and reseat your video card and clean your system out with the compressed air. Make sure your computer is completely shut down properly and is unplugged from the outlet when you do this and before you work inside the case make sure you touch the metal side to discharge any built up static electricity you may have so that it does not cause damage to the sensitive components inside your system. If possible you might want to take the monitor and connect it to another computer system, if it works properly on that system, more than likely it might be your video card. Hope this helps
Jun 25, 2008 | Acer AL1912 19" LCD Monitor
Pc locks up
Have you rcently installed something that could be causing the issue? Without knowing exactly what happened prior to the problem, I would recommend using the Restore CD that came with your computer. That should solve you issue. It takes normally anywhere between 30 minutes to 2 hours, but it might save you time in the long run from troubleshooting. Just remember to save anything on your computer that you need that wasn't there when you got the computer to a cd or disk before you do the restore.
Aug 24, 2006 | Gateway (2900147) PC Desktop
HP Pavilion a450n PC Desktop Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
