Question about Speed Queen AWN412 Top Load Washer
Water will not come in with timer pulled out it goes into wash cycle
    Problem Solver:
  • 19 Answers
Possible bad water level switch or bad timer.
Posted on May 03, 2010
  • 1462 Answers
SOURCE: Front Loading Washing Machine - stuck in cycle.
there may be a simple solution. on rinse the water level is higher. it is just possible that the water is syphoning out. try putting the drain hose higher in a swan neck
Posted on Apr 06, 2007
ahamed100
  • 148 Answers
SOURCE: Will only start water when in wash cycle
  • The diaper pail we suggest using is the size medium Diaper Pail with Carbon Filter, or, if you want a really big pail, the American Diaper Association approved 54 QT Diaper Pail. We sell them at Diaper Safari! They are nice and big andboth have a slot for a Citrus Circle which helps eliminate odors.
  • Try using a mild and environmentally safe detergent like: Bi-O-Kleen, Allen' Naturally or ECOS. You can also use Arm & Hammer for sensitve skin or Sensi Clean - do not use Dreft!
  • A Citrus Circle or a little baking soda some tee tree oil in the bottom of the diaper pail liner will help against odors.
  • Diaper Pail Liners can be our re-usable waterproof pail liners or standard 13-gallon kitchen trash bags.
  • Sprinkle a few drops of BacOut Stain & Odor Eliminator on the diaper if "poop" got onto the diaper itself.
  • Adding a few drops of Tee Tree oil to the main wash leaves diapers smelling fresh and kills bacteria - not for pocket diapers.
  • Sun-dried diapers and covers become snow-white. Try this as often as the weather allows.
  • Use the dryer for a few minutes to soften sun-dried diapers that get stiff.
  • Wash and dry new diapers one to five times before wearing - for unbleached diapers this will remove the natural waxes and will fluff up the cotton, which gives the diapers their absorbency. You will only need to wash the covers, Fuzzi Bunz and AIO once or twice at the most.
  • Spray any solids off with the Mini Shower - it makes makes cleaning cloth diapers very easy
  • Don't let wet and clean diapers sit in the machine overnight.
  • For serious stain you can try something like Spay and Wash.
Posted on Feb 29, 2008
  • 177 Answers
SOURCE: washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Posted on Aug 12, 2008
  • 36 Answers
SOURCE: Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Posted on Jan 02, 2009
SOURCE: Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Posted on May 02, 2009
THE WASHING MACHING FILLS WITH WATER, GOES THROUGH
Most Likely it's the timer. try to move it by hand to the net cycle. If that doesn't work it's the contacts on the inside fouling up.
Sep 06, 2009 | Whirlpool Washing Machines
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
    That is probably a problem with the timer.
  • Oct 11, 2008 | Bosch Washing Machines
    Washing Machine
    timer sounds most likely..had the same issue a few times
    Jul 01, 2008 | Whirlpool Washing Machines
    Maytag Washing Machine Stops after wash cycle...
    sounds as if you have abad contact in the timer
    advance the timer to a different spin cycle and see if it spins
    then bo back to where it stops
    if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
    Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
    Maytag washer lse7804a won't fill
    with the timer in the wash position on any cycle do you have 120 volts on the selenoids that the water hoses are connected to with the temp selector set for warm wash and timer knob pulled out? if you do then the water inlet valve is the issue, if no voltage you could have gotten a defective timer
    Apr 10, 2008 | Maytag LSE7806A Top Load Stacked...
    Apr 05, 2007 | Frigidaire GLTF530DS Front Load Washer
    Speed Queen AWN412 Top Load Washer Logo
    150 people viewed this question
    Top Speed Queen Washing Machines Experts
    Terry Schneider
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
