Question about ECM Giotto Espresso Machine
My 5 year old Giotto has stopped working
I have a 5 year old Giotto. Today when I turned it on the pressure immediately skyrocketed. I turned it off and back on again. The pressure gauge returned to its normal position. When I opened the steam valve I had no steam and the pressure gauge dropped to zero - the same thing happened when the hot water valve was opened. When I turned on the brewhead water came out but it was like warm. When it is turned on now it makes quite a racket. Any advice ??? Thanks
  • daly_val May 05, 2010
    Guru,
    I may need a little more assistance. I have looked at several websites for "vent valves"for the ECM Giotto and can not find a part number with that name. Any suggestions as to the part number and source for this part?
    Thank you once again.
  • timjim
    timjim Jul 24, 2012
    I THINK by "vent valve" he actually means the "breaker valve" - Part #: C219900560 Breaker valve (Part 21 in the boiler-parts diagram).
    President:
  • 1,618 Answers
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
Posted on May 04, 2010
Testimonial: "Thank you so much - you were absolutely correct and your advice worked. I will order a new vent valve today!!"
  • Ernest R
    Ernest R May 06, 2010
    It is a universal valve check this site espressoparts.com. You just need a regular vent valve some call it a vacuum valve.
I have a Giotto ECM esspresso machine. it is approximately 3 yrs old. recently when i turn the machine on, it starts heating up, but it doesn't create any pressure. any suggestions how to fix this problem.
Hi
1 solution is your vacuum breaker valve is sticking. Try opening the steam valve and see if you can start to heat again. If it does just, replace your vacuum breaker valve.
Sep 20, 2010 | ECM Giotto Espresso Machine
Giotto Premium problem...
Try to do a hard reset by unplugging the device from the power outlet or take the batteries out and wait for sometime to reconnect.
May 29, 2008 | ECM Giotto Espresso Machine
ECM Giotto
sound like it need to taken apart for a good cleaning. Hard water will cause build up ..your user manual should tell you how. i have the manual. It says Hard water will cause that problem.here is the link for the manual.http://www.espressotec.com/store/pc/catalog/pdf1/ec1300_ecm_giotto_manual.pdf
Jan 02, 2008 | ECM Giotto Espresso Machine
Help w/ ECM Giotto. pump doesn't turn on when pulling lever
Replace the magnets in the water tank, the reed switch is not reading one of them, most likely the safety or bottom magnet.
Feb 03, 2010 | ECM Giotto Espresso Machine
My 39 month old pump stopped working today. Can
Any dealer can repair it. These pumps have a long life.
Dec 03, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Problems with my gauges or engine?
mcdevito75 here, It could be the gauges, specially if the y stay at the top, if these are the only 2 gauges that act this way it could be the oil and coolant temp. sensors on the engine itself. Have your repair shop check these out.
Mar 31, 2009 | 1998 Ford Econoline
Machine is on but no pressure and no attempt to make any
Open the top panel of the machine there is a small reset thermostat, that may have have tripped, push in to reset(sometimes reset is on the element).
Mar 31, 2009 | ECM Giotto Espresso Machine
Giotto pressure valve constantly on
You must have an internal leak and your machine will need to be serviced. If you can remove the top of the machine maybe you can see where the leak is coming from and may be able to repair the machine yourself.
Cerini Coffee
Espresso machine service and Sales
www.CeriniCoffee.com
Nov 10, 2008 | ECM Giotto Espresso Machine
Giotto premium - is it a lemon?
My friend, had the same feeling,,,What have a done !! This piece of junk for all my dollars! No ,,it needs cleaning. Read all my comments re this. You can open this machine witha few fixed keys and mantain it. It will outlast you, when correctly mantained. All solid cupper and metal, no plastic. take it apart and CLEAN IT!
Remember - it is built by a human beeing. The ECM is a buty as it has very little automation built in. Very siple function = löong time in love with your machine. It is totally ANALOG = tweek it = better cogffee. /// Olev
Aug 23, 2008 | ECM Giotto Espresso Machine
Air pressure problem
I am having a similar problem.  Doesn't happen all the time, just sometimes.  My research has led me to believe it might be the vacuum breaker valve.  I am going to order a new one here:
https://www.chriscoffee.com/products/home/parts/vbreakervalve
I'll replace mine & post if it fixes it.
Good Luck
Sep 02, 2007 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
539 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
