Question about Samsung Televison & Video
I have a samsung HLS 5086WX XAA and the tv keeps turning it self off. Got rid of all dust. I have 3 lights flashing the stand by/temp - timer and lamp. Thank you,
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
caroldon
  • 17129 Answers
SOURCE: I have Samsung model #HLP4663WX/XAA.
If the set powers off after coming ON for some time, then it is possible that there can be the following problems.
So check these tips.
1. When the set switches off , tap on the power board and main boards, if the set power back now, then the fault can be poor soldering on the power supply or main board.
2. If you notice that the TV cuts off when a particular section heat up( you must check this with the set switched off, touching the different sections) , if so force cool this section and see if the set switches back. Alternatively you can simulate the heating or cooling using a hair dryer or a freeze it spray, so that the particular suspected area can be found.
3. when the fault occurs, check the voltages on the main board, the power supply , check the rail and + B voltages, particularly to the driver sections.Only a good trace of the missing voltage will lead you to the fault. So take the tip from a missing voltage on shut down.
Finally solder all IC pins, power drivers pins and connectors.check this link for soldering tips:
http://www.solder.net/technical/tips.asp
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Oct 19, 2010
  • 1156 Answers
SOURCE: My TV keeps sutting down.
The power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
Posted on May 27, 2011
  • 20 Answers
SOURCE: samsung model hlt4675sx\xaa projection tv
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Posted on Aug 12, 2011
chesterpendi
  • 195 Answers
SOURCE: My samsung tv has sound but no picture and the
Try to replace the lamp or light engine..
Posted on Feb 23, 2012
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
Samsung DLP Flashing Lights
Make sure lamp is in correctly and as far as the color wheel: The ribbon cable from it to the DMD box only has connections on one side where it plugs in---it is possible to put it in backwards and set will detect wheel is not working..............
Jun 14, 2012 | Televison & Video
Samsung Flashing Lights
a new lamp is possible or even the ribbon cable from the wheel to the engine may be in backwards.
My sanding tv hlt4675sx xaa keeps turning off. When I turn it back on here a little grinding noise... now when I turn it on can here the fans come on nothing else. No light from the bulb is showing from...
It sounds like the color wheel has fallen apart. I would recommend calling Samsung at 1-800-samsung to find the closest service center. This can be a difficult repair and I would strongly recommend a Samsung authorized repair center.
Aug 01, 2011 | Samsung Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
