Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Error Code E-000000-0000 I had an error code E-000002-0000 and I completed the *2,8,* and cleared that error up. Now I have the other error. Please help.
  • pattispiv May 03, 2010
    Hi Rylee...
    When I am in service mode no 2 and 3 don't work. Am I missing something?
    Please respond. Your steps don't do anything. Perhaps I am doing something wrong.
  • Canon Master
  • 12,061 Answers
Http://www.dndlaser.com/products/kits/pdf/HP%202200%20Maintenance%20Kit%20Instructions.pdf
http://www.blueridgecopier.com/User_Manuals/Ir3300/imageRUNNER%202200_2800_3300%20Reference%20Guide.pdf
THe error code states that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
You may be able to get away with just doing an error reset. Service mode, Copier, Funtion, Clear, Error. Then reboot machine and presto.
Very often E000 is due to a sudden power outage. Possibly because the mod to the DC power supply hasn't been done (replacing a resistor with a capacitor and resister piggybacked). Worth a try.
clearing the error may not fix the fault
Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
Posted on May 04, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error E000 means low temp detected in the fuser unit, Faulty thermistor, lamp or PCB. Check fuser for jammed paper. It’s an issue related to the fuser unit. Try and clear the error by entering the service mode:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistor. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 03, 2010
Solution off error code 000002 off IR 3245 Canon ?
Hi. That error means there was a temperature error . You need to enter into service mode to clear that error.
with the copier powered on press the next secuence
press adittional function once
press 2 and 8 at the same time once
press adittional function once again.
service mode should appear in the screen. If it doesn't. Repeat the procedure.
with service mode in the screen :
select COPIER.
Select FUNCTION
Select CLEAR
in the list below select ERR and press ok in the lower corner of the screen .
turn off from the main switch of the machine for about 10 seconds.
power on the machine and make some copies .
if problem persist that mean that fixing heater is defective and need to be replaced
Feb 26, 2018 | Canon Office Equipment & Supplies
E.000002 on canon ir2545i, whatdoes the error means, and how do i fix it.
Hi. That error means there was a temperature error in the fusing unit . The error can be cleared.
need to enter in service mode
in the control panel do the next key secuence:
press 2
press 8
press again adittional function.
service mode should appear in the screen: (#SSW)
tap in the arrow ? or ? and search for CLEAR
press OK once, with arrows search for ENGINE and press Ok once, with arrows search for ERRCLR and press OK once more.
turn off the machine from the main switch for about a minute and restart it. try to make some copies, if problem persist there is a malfunction in the fixing unit, get technical support.
if this answer was helpfull , please rate it. thanks
Feb 18, 2018 | Canon Office Equipment & Supplies
How do i fix it this code in canon ir 3570 copy machine the code 000002
This code is nothing but voltage error code. First you have to cancel the code by doing as below
Service mode ----- function-----clear-----then click on all the options available in the fist page, first click one option then press ok, like wise to all the options available in the first page.
then switch off/on the copier. The copier will be ready.
To avoid this error please put stabilizer for 220v and for 110v put step down with stabilizer.
Oct 10, 2015 | Canon IR3570 COPIER FOR 220 VOLTS ONLY
Error code 000002 0006
It's a high voltage error. The machine probably needs the fuser rebuilt.
You can temporarily clear the code in service mode.
(if you dont do it fast enough the screen will shut off, just reboot and try again.)
hit additional functions.....let go
hit the 2 and the 8 key together.... let go
hit additional function ......let go
then on the screen hit
copier...
function
clear
err
then push ok on the screen, after that reboot the machine from the main power switch and it should clear.
May 15, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
WHAT Cannon image runner 2525 ERROR CODE 000002
The main thermistor (TH1) has poor contact or open circuit. The thermal switch (TP1) has open circuit. The SSR is faulty. the DC controller is faulty.
The temperature of the fixing roller does not reach 100C with 2 min after it has exceeded 70C.
Apr 28, 2014 | Canon imageRUNNER C6800 Copier
Error code +0001 +131 000002-3169+0813
horizonal movement is the problem. Usally cleaning the carriage bars will clear this up if not a new motor is needed
Dec 26, 2012 | TallyGenicom 2265+ Matrix Printer
Canon CLC 3200 error 000002-0102
This is mainly caused by Power Problem in cannon 3200, Change the complete fuser assembly as one of the thermistors has gone open circuit, just by ordering up the single parts costs the same as buying the complete thing. Also, if required, reset the code *28* function.
good luck, feel free to get more assistance, do rate the solution if got help.
Dec 09, 2010 | Office Equipment & Supplies
Error code 000002-0010
You need to clear this fuser roller heat rod error in svc mode.
Additional Functions="star"
2and8= hit both keys same time.
Svc mode= star 2and8 star
copier/functions/clear/err/ok
reboot
If there is areal problem with fuser heat rods it will code again.
Nov 08, 2008 | Canon imageRUNNER 5000 Copier
Error code 000002 on cannon image runner
You have to get into service mode and clear the code. First, press the aditional funcation botton on the control pannel then the numbers 2 & 8 at the same time then press the aditional funcation key again. The diplay should change. Press the copier box and the at the top in the middle of the display " Funcation" the display changes again, then in the 2nd colum about half way down you will see "Clr" touch that box and then at the bottom right of the display touch the " OK" box then turn the main power switch off then back on and that should solve the problem. You may have a bad power problem with the wall outlet if it is not the right voltage, it will play havice with the copier. Good Luck
Mar 31, 2008 | Office Equipment & Supplies
Computers & Internet Logo
1,009 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
