Question about Fuji FinePix S1000FD Digital Camera
How do I make my shutter speed faster? - Fuji FinePix S1000FD Digital Camera
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 241 Answers
Shutterspeed depends on 3 things: the amount of available light, the aperture (lens opening) and the ISO setting.
Every full step you can open the aperture (like from F8 to F5,6) will half the shutterspeed. And every time you double the ISO, the shutterspeed will half. Raising the ISO will increase the noise in the picture.
Mode P, S, A and M will allow you to make these settings manually. If you use the N mode, the camera will do most of these things by itselves.
Posted on May 04, 2010
Shutter speed
Like most point&shoot cameras, the A3100 does not give you direct control over the shutter speed. You're expected to just point the camera and shoot, without worrying about such niggling details.
You can gain some control over the shutter speed by changing the scene mode. For example, portrait mode attempts to reduce the depth of field by opening the aperture, which results in a faster shutter speed. Conversely, landscape mode attempts to increase the depth of field by closing the aperture, which results in a slower shutter speed.
Dec 20, 2013 | Canon PowerShot A3100 IS Digital Camera
I have a D60 and when using my new lighting kit if the aperture is faster than1/200 it creates a blackout across part of the image due to the mirror. Any solutions?
It's not the aperture, it's the shutter speed. It's also not the mirror, but the shutter.
The camera's fastest shutter sync speed is 1/200. You must use a shutter speed no faster than that. Due to the construction of the shutter, the frame is not fully exposed simultaneously at faster speeds and thus part of the image is blacked out.
Using a flash, the amount of light is controlled almost exclusively by the flash; the exposure is controlled by the aperture and the shutter speed is all but irrelevant.
Feb 15, 2013 | Nikon D60 Digital Camera
Picture from camera not clear
There could be any number of issues, unfortunately, your problem description doesn't give enough information, but here are some ideas.
Likely, the culprit is either a problem with focus or a problem with camera shake. In either case, brighter light and/or using a flash should help as auto focus works better in bright light and the shutter speed is faster in bright light. (With a faster shutter speed, there is less time for the camera to move while the image is recorded).
If using auto focus, be sure that the focus point illuminates on your main subject.
Many point & shoot cameras have an indicator if the shutter speed is too slow for a hand-held shot (typically occurs with low light). If this is indicated, then use a tripod (or brace your arms/elbows to make a human tripod) or increase the ISO of the camera (may have to go to manual mode) to avoid camera shake. Holding the camera at arm's length to look at the display while taking the picture is a recipe for camera shake & blurry pictures. You can rest the camera on a shelf and use the timer so that your hand motion pressing the shutter button isn't an issue. If using an SLR, ensure that the shutter speed is faster than the reciprocal of the focal length. That is, for a 100 mm lens, the shutter speed should be faster than 1/100th of a second.
Feb 25, 2011 | Cameras
How do I change the shutter speed?
You can't change the shutter speed on a point-and-shoot camera. You can change modes and some settings that will force the camera to fire the shutter at faster speeds. For example, if your camera has a "sports" mode, that will fire faster. You can set the ISO to a higher setting to cause the shutter to fire faster.
May 14, 2010 | Nikon Coolpix S1 Digital Camera
I mounted the Canon 580EX II to my Canon 5D Mark II. When I using Manual Mode, I can't set the shutter speed more faster then 1/200 sec. Is this problem normal/limitation of it?
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
May 11, 2010 | Canon Speedlite 580EX II TTL Flash
Adjust shutter speed
On most indoor shots the shutter speed will normally be 1/30 if you need or want it to be faster than that the only way to do that with this camera is to set the ISO to a higher value. Page 29 of your user manual explains how to set the ISO value for the camera to allow for faster shutter speeds.
May 01, 2009 | Olympus Stylus / mju 1050 SW Digital...
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
I need to change settings for samsung L201
You can reset all settings to the original defaults by following the instructions on page 74 of the manual:
http://downloadcenter.samsung.com/content/UM/200810/20081006113527265_L200_English.pdf
Page 41 explains the ISO settings, which seem to be straight forward to me.. The larger the ISO number, the greater sensitivity to light, so the faster shutter speeds you can use (the larger the shutter speed number the faster it is - ie 125 is faster than 60). The drawback of the ISO is that more noise will appear in the images (dark areas look grainy)
To avoid blur, either take your shots on a tripod or ensure that the shutter speed is at least 1/60 of a second
Dec 28, 2008 | Samsung L200 Digital Camera
Shutter speed
Sounds like you are having some photo taking issues. There is a rule of thumb for shooting, It is the focal length must be equal to or less than the shutter speed. Example. 100 mm lens must have 1/100 of a second or faster when hand holding a camera. If your shots are too blurry or out of focus, try using faster film speed, ie. 400 asa or 800 or 1600, try using a flash if you are going to be at 1/60 a second. The faster the film you use, allows you to have a faster shutter speed. Another option is to use a tripod, and then your shutter speed is irrelevant.
Dec 27, 2008 | Nikon FE 35mm SLR Camera
Shutter speed
shutter speed has nothing to do with battery power. If you have a SLR camera you use the shutter speed option when you want to have control of the shutter speed, slow shutter speed means if your taking a picture of a waterfall and you want to see the actual droplets you set a slow shutter speed, if you want it to look more smooth/flowing you set a faster shutter speed, if you do not have a SLR camera you probably dont have much say so in shutter speed...
May 28, 2008 | Nikon FE 35mm SLR Camera
Fuji FinePix S1000FD Digital Camera Logo
76 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
