Question about IBM ThinkPad T40 2373 Notebook
IBM t40 think pad wireless won't turn on, I can see the light but will not connect
    Guru:
  • 109 Answers
Try to restart the Services of Wireless Zero Configuration or Wireless Auto configuration in the Services Section. To open service, type "services.msc" in the run command.
Posted on May 05, 2010
Where is the Wireless "ON" switch
Posted on Dec 20, 2010
5 Suggested Answers
martmet
  • 52 Answers
SOURCE: dont know how to turn on the wireless to my ibm think pad t40
Hi, there is a switch usually on T series laptop. But some models dont so if you dont find a swtich anywhere near the front or the sides, you need to reinstall the drivers. Desactivate the device and enable it again may do the trick (Start->settings->Network Connections-> Wireless network connection (right-click then desable... wait until you see the device going gray then right-click enable. Try that and if you still have issues, let me know.
Posted on Jun 08, 2009
  • 166 Answers
SOURCE: inter net wont work
clarify please. dont have a clue what you did, or need to do. who do you use for internet, are you plugged in or wireless. if wireless make sure its on, usually a tiny switch or a combo of FN key and another key that looks like wireless being sent.
Posted on Sep 03, 2009
  • 73 Answers
SOURCE: t40 2373 no wireless connection
Hi it sounds like your driver is missing or corrupt , this may be the case if u have recently installed windows, go to control panel click on sytem icon then click on device manager button under the hardware tab, have a look then under network adapters to see if there is a yellow warning icon if so make a note of the name and you should be able to download the driver from this location. its near the bottom under networking wireless.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46258
please rate ! hope this helps :)
Posted on Feb 10, 2010
eddiet20
  • 39 Answers
SOURCE: can't connect to internet on my IBM T40 think
You need to supply some more information, are you trying to connect wired or wirelessly? For either first see if your network adapters are installed. Right click on "my computer" either on desktop or start menu. Then choose properties then hardware then device manager this is slightly different depending on your operating system but you need to get into the "device manager" Google it if you cant find it. i.e "how to get into the device manager in windows vista" Once in look for the "network adapters" tab drop down the + sign and see if they are both listed and there are no "!" going thru them, if there are then you need to download drivers, if not and they are installed properly then to connect "wireless" you should see a series of bars by the clock on the right side of the taskbar some computers have a switch to turn the adapter on or off some have a key combination such as fn+f2 or f5 etc., there will be a wireless icon on the key to identify it. If on then when you left click on the bars you can choose veiw available networks, choose yours and highlight it and choose connect, if it is a secure network you will need your network key or passphrase. Wired: just plug it in to the ethernet port and it will try and connect to the network. If you are getting a limited or no connectivity icon you must reset your modem and router in this order. Disconnect (power) to your modem and router if cable unscrew coax cable also. all lights out screw cable back in, then power on your modem..WAIT for all lights to come on solid (with dsl the dsl light should be on and solid not blinking) once your modem is up then plug in your router wait for all lights to come on. Thsi should put your computer online. If not, open internet explorer then go to tools / internet options / lan settings make sure that proxy server is NOT checked. If it is uncheck it and choose "automatically detect settings" above it. Most likely if it was checked you have some rogue phony antispyware on there and your computer needs to be scanned for issues. one last thing you can always right click on the intenet icon by the clock and choose "repair" wired or wireless it will reset the adapter and correct the problem. I think I covered everything not knowing your OS
Posted on Jun 19, 2010
LOOKING FOR THE ON/OFF WIRELESS SWITCH FOR AN IBM T41 THINK PAD, I THINK IT GOT TURNED OFF ACCIDENTIALLY. LENORE07407@YAHOO.COM
Try pressing Fn+F5, this is the standard on IBM laptops for enabling/disabling the wifi connection.
Jan 18, 2011 | IBM ThinkPad T40 2373 Notebook
T40 2373 no wireless connection
Feb 10, 2010 | IBM ThinkPad T40 2373 Notebook
I have an IBM think pad T40 that does absolutely nothing when I try to turn it on. It's actually my daughters, she sid it was working just fine then she shut it down and when she came back an hour later it...
Try taking the batter out and booting using just the power cord and Vice Versus'. Also when the power is plugged in does the charging light (Battery Indicator) blink or light up? If you know the Power Supply is good, then the Mother Board may have fried. If it's under warranty, take the Hard Drive out and send it in.
Dec 20, 2009 | IBM ThinkPad T40 2373 Notebook
Inter net wont work
Sep 03, 2009 | IBM ThinkPad T40 2373 Notebook
How to fix the wireless controler in a think pad
When you download the T40 device drivers from the IBM/Lenevo WEB site make sure you select your model laptop and, they need to be the XP or Vista versions of the drivers you need.
When you run the driver programs they will be unzipped/expanded to the hard drive in a folder c:\drivers. Then you need to open the various folders and run the setup programs to install the various drivers.
NOTE - The T40 series laptops come with various different manufacturers devices (eg. there are a few different wireless model LANs) and if one version driver doesn't work you need to install a different one. It is a bit of trial and error to find the right one
Jul 22, 2009 | Computers & Internet
IBM think pad t40...the screen stays black. Shows
Are the activity lights blinking like the computer is doing something? If so the monitor may be disconnected from the unit or damaged. If so this is a pc repair issue, and a little tricky to do on your own.
Jul 03, 2009 | Battery Technology IBM ThinkPad T40, R50
Dont know how to turn on the wireless to my ibm think pad t40
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.moz-screenshot.jpg0d7fbfc.gif
Jun 08, 2009 | IBM ThinkPad T30 2366 Notebook
Wireless without a cable
Some T40 series (especially T42) laptops have built-in wireless cards and you only need to install the wireless driver.
If you don't have a built in wireless card you can purch a PCMCIA wireless card and inset it into the PCMCIA slot on the laptop.
These cards are common and are available from several manufactories such as Netgear and DLink.
Mar 29, 2009 | IBM ThinkPad T40 2373 Notebook
T40 ibm think pad connections
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 25, 2009 | Visioneer OneTouch 5600 Flatbed Scanner
Need Wireless Card on my T40 23734NU
if u ve usb slot and pci slot in ur laptop u can use wireless, there are may brands available in market like belkin , netgear , u can connect install the drivers come along with the wireless card install it and u ll go online wireless
Nov 18, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
504 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
