Question about Samsung SGH-a727 Cellular Phone
Samsung SGH-a727: LCD display is blank (white) on the left 20% of the screen. The rest of the screen is very faded with vertical streaks through it. What's up? It hasn't been dropped or otherwise damaged.
    President:
  • 1,561 Answers
The screen of your phone as started malfunctioning.
It is possible that you hit it on a hard surface. all the same, it also possible that the screen is not well tighten to the panel of your phone.
Get a torx 6 screw driver, switch off the phone,remove the battery cover of your phone,the battery and sim card. turn the phone over and remove the front casing of your phone, use the torx 6 screw driver to tighten up all the screws on the screen to the panel very well and couple back yor phone.
Put back the sim and battery and switch on, if the screen did not still display, it means the screen of your phone is bad.
The problem is the screen, the screen is faulty and will need to be replace if you want it to display back as you use to have it.
All you will need to do is to get a get a brand new screen on your phone and i advice you go with the phone in other to get the exact screen and a working screen.
Take care.
Posted on May 03, 2010
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Center key, left, right, up, down, 2,5,8, not
New keyboard membrane required (keyboards often come in one piece, and you can get whole rows failing particularly with liquid damage
Good Luck
Jan 14, 2010 | Samsung SGH-a727 Cellular Phone
Samsung g800 mobile phone and the lcd screen display often will not display images & has to be restarted to display images
i have a samsung sgh-g800. phone just came back from repairs, replaced lcd and flex kit upgraded software and tested went to use the other day. screen is completely blank. has been charging for the past 2 hours still no change
Jan 08, 2010 | Samsung SGH-G800 Cellular Phone
Main Display Screen has faded so I can see numbers but not real good
The outer LCD screen is messed up now. Fixing this means replacing the front LCD screen... Go to a local repair shop..
Hope that'll help you..
Happy Holidays...
**please rate my post**
Dec 16, 2009 | Samsung SYNC SGH-A707 Cellular Phone
LCD Screen is will only display a white screen.
The inner screen cable contact would have got loose. You can carefully open the casing to reconnect the cable, or you can take it to a service center to get it fixed.
Aug 06, 2009 | Samsung Katalyst SGH-T739 Cellular Phone
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Samsung G600 mobile phone blank screen
sgh d880 screen is totally blank & everything is ok widout screen. everything is ok when connected to tv output, the screen is displayed on tv bt it is white on phone plz solve my problem.
Apr 10, 2009 | Samsung SGH-G600 Cellular Phone
Samsung sgh-A727 and I cant remember the power on password
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (10)
  4. Highlight, using the navigation keys, any of the following:
    • All: Phone, Display, Profile and Alarm settings will be returned to default values
    • Phone Settings: only phone settings will be returned to default values
    • Display Settings: only display settings will be returned to default values
    • Profiles: only profile settings will be returned to default values
    • Alarms: only alarm settings will be returned to default values
  5. Press the center navigation key to check the box(es) of reset settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is “00000000”
  8. Press the left soft key for Confirm
  9. Enter the password again to confirm, using the keypad
  10. Press the left soft key for Confirm
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Mar 11, 2009 | Samsung SGH-a727 Cellular Phone
Samsung SGH-a727 Cellular Phone Logo
167 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
