Question about Estate TAWX700JQ Top Load Washer
What is the volume of water if on extra heavy load does this machine hold?? thanks
    Problem Solver:
  • 19 Answers
On the highest water level 20-22 gals. per fill, wash, rinse, spray rinses, equal about 44 gals without a 2nd rinse option.
Posted on May 03, 2010
ERROR 5L WASHER MACHINE CALIPSO. THANKS
The error is SL.
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 15, 2010 | Washing Machines
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer stops and give an SL error code
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer failure and will need to be replaced.
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine clogged and rust and stink
to help clean the unit, do a large load of whites, extra bleach, extra-super-heavy-duty wash, hot wash and hot rinse. many small loads sometimes cause the unit to "smell up"
Sep 04, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Water leakage
its possible when you are doing a big load it demand more water so the water goes true the agitater seal which is located under that white agitater the seal is between the two shaft thanks from gilles
Mar 14, 2009 | Washing Machines
Machine runs through wash cycle and then in the rinse cycle gets an SL error code.
SL = Suds Lock
Feb 26, 2009 | Kenmore 22422 Top Load Washer
Maytag heavy duty top loading washing machine stopped and won't restart
remove console screws behind timer is lid switch if you have a volt/ohm meter with washer disconnected ckd switch operation also there is a fuse on same assembly ck it
Aug 17, 2008 | Washing Machines
It will not fill with water
how do you open top on whirlpool washer?
Jan 23, 2007 | Whirlpool LSR9434PT Top Load Washer
Estate TAWX700JQ Top Load Washer Logo
35 people viewed this question
Top Estate Washing Machines Experts
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
