Question about Kenmore 82722 Electric Portable Dryer
Thermal overload? Dryer shuts clicks off after 5 seconds and smoke comes from the motor. After a few moments a reset ? click is audible then you can re start the dryer. We took it all apart and cleaned it, made sure it wasn't getting any drag from the belt or fan- ran it with out the belt but it does the exact same thing.
  • 25 Answers
The windings in the motor have been overheated to the point that the insulation is burnt off. I call this pre installed smoke. If it is let out replace the motor. There should be a local appliance parts dealer that can help you get the motor.
Posted on Mar 26, 2008
Marathon electric motor thermal overload shut down
if it has 2 caps, yes the cap in the back of the motor (black plastic) is for starting motor, and if it has a metal one on the top, this is the run cap, if the run cap is bad it will trip the thermal after a few moments. but make sure you have the voltage set for your application.
Feb 06, 2014 | Marathon Electric 1 H.P. Round Flange...
Sunlighter hot tub
Sounds like the pump motor is tripping out on thermal overload. Touch that particular motor just after it shuts off. If it is "very" hot to the touch, it probably needs replacement.
Oct 16, 2013 | Electrical Supplies
Kitchenaid dryer model kgys750jq0 wont start
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive. Here is the switch to order if it is bad.
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset. Here is the fuse to order in case it is bad.
Post back your findings and I will post the repair video for the repair.
Nov 07, 2012 | Dryers
My dryer only runs for about 5 minutes then shuts off, as if overheated. You have to wait about 10 minutes before it will start when you push the button, only for it to last only another 5 minutes.
Sounds like you might be causing the thermal overload of the motor to open shutting down the dryer. Try cleaning out all the vents--external to the outside and internal to the dryer. Cleaning out the internal ones will require you to open the dryer up. Be sure the dryer is unplugged before any work is done to its internal workings or the control panel is accesseed. Often times, lint inside the vent or just inside the dryers internal areas can collect near the motor and overheat it. Cleaning this out may aleviate your problem. If this does not work, it may be time to look at a new motor--or dryer replacement. Usually when a motor starts to have internal electrical winding problems there will be a horrible sounding buzz upon start up. Remember, a thermally overloaded motor only has so many restarts before it is done.
Feb 05, 2011 | Maytag Dryers
Has started to beep whenever items plugged into
If it's more than 3 years old, you probably need new batteries.
If the beep started after plugging anything additional into the UPS, you may be in an overload state, and the beep is telling you that it's choosing to beep and not function as intended rather than smoking itself. Try unplugging a piece or two from it and see if the beep goes away. If not, probably just you're batteries giving out due to old age, they'll only give you 3-5 years.
Oct 11, 2009 | Dynex Computers & Internet
Dryer starts then shuts off
it seem like your motor could be faulty (overheating) causing the thermal overload to open, stopping the motor after awhile it will cool down and the thermal will reset, if this the case the bearings or the windings could be faulty
Dec 13, 2008 | Dryers
Dryer won't work
Hi ginisa;
There might be a thermal cutout on the motor that drives the drum. You can check this by removing the back of the dryer. Most of them come off after removing a few small bolts. Look for a red button on one end of the motor. BTW, unplug the dryer before you take the back off. If you find the red button push it in and then plug the dryer in to the wall and see if it will run.
The thermal overload is a safety device that shuts things off if the motor gets too hot. So even if it does start and run, check it closely so see if it gets hot.
Hope this helps Good Luck Loringh
PS please leave a rating if appropriate Thanks
Nov 22, 2008 | LG DLE2532W Electric Dryer
After a few loads the dryer shuts off before the time cycle is finished. The lent screen is clean and the lent exhaust is clear. My dryer is whirlpool mod. GEQ9858JQ8.
the motor is over heating cutting out on the thermal overload inside the motor replace the motor 279787 part number
Apr 17, 2008 | Dryers
Robot Coupe clicks, runs 5 seconds, stops for 30 seconds, clicks, runs 5 seconds...
The clicking noise is an internal circuit breaker or motor protector. These things are not made to be bogged down or overfed. The motor is heating up & tripping the overload, after cooloing it resets. Time to buy a new one or get the motor replaced ($600-$800)
Oct 29, 2007 | Robot Coupe R100 10 Cups Food Processor
Kenmore 82722 Electric Portable Dryer Logo
120 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
