Question about Toro Lawn Mower With Toro Power Tools
I HAVE A TORO Z420 MOWER. THE BATTERY DOES NOT CHARGE WHILE IN USE. I HAVE TO CHARGE THE BATTERY EVERY TIME AFTER CUTTING THE LAWN.
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
  • 33 Answers
SOURCE: Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
Posted on May 02, 2009
  • 86 Answers
SOURCE: Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
Posted on May 16, 2009
wadembly
  • 513 Answers
SOURCE: Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Posted on Jun 06, 2009
Toro 50" ss5000 time cutter with Kawasaki 22hp engine battery wont charge. Allow me to only cut about 3 times before battery is drained.
Take battery out, charge with 12v auto charger. In a couple days check voltage 12 or better
Jun 23, 2016 | Toro Garden
How much and what do I put in gearbox of my Toro z420 mower
these are sealed transmissions. unless your rebuilding it, don't change the oil.
Oct 15, 2015 | Toro Garden
Is there a place to check the hydraulic fluid on a 2005 toro Z420
sounds like your hydraulic motor maybe acting up. you need to check your hydraulic oil flow rate. if you don't have the tools you would have to take it in it is a fairly big job
Oct 07, 2014 | Toro Power Lawn Mower
Hey! I thought you was gona send the wiring diagram for that toro z420
It's in the mail. Should get there in another week or two.
Aug 11, 2014 | Toro Garden
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Jul 23, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
My timecutting z420 won't start. No sound when I turn the key.
check [clean] your battery connections , Charge the battery.
If the battery is older than 5 yrs it may be worn out.
May 10, 2014 | Toro Lawn Mower With Toro Power Tools
We recently bought a second hand Toro Z420 ride on mower but there wasn't any manuals with it can you help as I can't seem to print one from your site even though you say we can?
hi there pauly 46 here
hi peg ed
here is web site to download service manual
http://www.kohlerplus.com/main_frame.asp
enter as guest
select kohler courage single, then scroll down to service manual , then select SM 20-690-01
(replaces tp-2548 a) and download a copy to your hard drive its 6.05 Mb
here is web site for toro manual
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
under manuals , enter 74327 as model , time cutter z420 will come up in a list of 2
see if this will let you print anything
cheers
May 16, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Replacement blade position.
The blades have such a close tolerance tip to tip on a V belt deck that it makes no difference where they are positioned, On a 3 blade deck the center spindle is forward of the two outer spindles. So for that reason you still get a quality cut. Most all commercial units use a V belt and have a good quality cut.
Some john deere mowers have a timing belt with cogs like a car and their blades have to be in time
90 degrees perpindicular to each other and locked down and if you strike something then the timing will be off and your back working on your mower instead of cutting grass,and the belts are twice as expensive than a v belt.
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
181 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
