Question about Whirlpool Microwave Ovens
My husband turned the power off to try and work on it..He did not do anything to it and now it won't start back up.Is there a code we need to enter.It lights up but no beeps on the buttons??
  • Whirlpool Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
Posted on May 04, 2010
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Won't start but timer works
Check primary and secondary interlock (door) switches. DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | Viking Professional Series VMOS200BT
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Menu bar shows code H 97 on model number NN-CD989S. started to cook microwave meal, the oven madepoping sounds and showed the H 97 then won't turn back on. there is a small sokey area below the...
This oven is programmed with a self diagnostic failure code system which help for troubleshooting -H97 and as described above "mica piece and burnt smell" sound like Inverter Power Supply. DO NOT try to repair or re-adjust preset volume on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very high current Operating a misaligned inverter circuit is dangerous due to the Very HIGH voltage and current that is produced by this board.
Defective board must be replaced with new one -INVERTER POWER SUPPLY.
Aug 23, 2011 | Panasonic Microwave Ovens
I have a built-in AEG Microwave code MC166(0E?) My son unfortunately used the microwave as a timer so it was on for 30mins without anything in it. It now won't turn "on"; no light/clock...
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
May 11, 2011 | Microwave Ovens
Won't work
unplug your microwave; remove the top under the top you will see a small white cylinder
(a ceramic fuse) it looks like a glass fuse only made of white glass replace this they are sold at radio Shack
Apr 22, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Micro wave just quit working
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 28, 2007 | Magic Chef MCD1311ST Microwave Oven
Maytag Over the Range Microwave
Assuming the entire power line from the breaker to the microwave cord is okay, it's almost certainly a bad connection on the circuit board of the control panel assembly. For reference, we repair these from all over the country for $32.50 postpaid.
Oct 16, 2006 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
127 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
