Question about Plumbing
Ran out of water about a week age came home today and only have 12 pounds of pussure
  • 349 Answers
Check any filter you may have in line to make sure it isn't stopped up, also check water tank to verify air pressure is 28 psi for a 40 gal tank it should have a sticker with what you need on tank in a empty tank turn water off and drain tank and check air in tank with tire gauge . tank should have a fitting on top of tank.
Posted on May 03, 2010
We just purchase home weeks ago.I opened the bosce dish washer found it had a musty order.The following day i ran a dish washer agent,which didn't work.clean the washers filter noticed green algee.
Put two cups of bleach in it and run it on a long and hot wash. The best way to stop the odor is to use it regularly and leave the door open for 15 minutes after you use it so it can dry out a bit. There will always be some water in the bottom in the pump.
Sep 23, 2017 | Cars & Trucks
IS A DIASTOLIC OF 50 AN SYSTOLIC OF 114 / HEART RATE 70 TO LOW
The 50 of 50/114 is a little low, the 114 is good. Talk to your physician as taking the meds every 12 hours may be wrong for you.
If you are checking your own blood pressure, always take it 2 or 3 times a couple of minutes apart and write it down. Take your blood pressure morning, lunch, evening and bedtime. Do it for a week and take the results to the doctor.
I take Diovan HCTZ which also has a diuretic. You probably realise, you need to lose a few pounds.
Aug 18, 2017 | Health & Beauty
Whirlpool cabrio dryer has water in it. Lent filter is also wet. Last time used was over a week ago. Why? Have had dryer for over a year and never have i encountered this problem with this dryer or any...
this happen with the dryer A typical 12-pound load of laundry weighs about 20 pounds when it emerges from the washer, meaning that a dryer has to dispose of about a gallon of water with every load. Because of the moisture, exhausting the dryer to the outside is recommended since indoor exhausting can cause mildew and other problems.
Typical ventilation is recomend see the diagram .God bless you56ed11ca-7868-4b1a-955e-88eafd615327.gif
Jul 13, 2013 | Dryers
Is it true that San Pellegrino's bottled water contains uranium?
The uranium in San Pellegrino was reported by a German TV program in 2007. But Nestle later responded by saying that all bottled and even tap water contains levels of uranium, and that the levels in San Pellegrino are safe, though they advised infants under the age of 12 weeks not be given San Pellegrino.
Feb 06, 2013 | Wine & Spirits
Ek dada,ek baap,ek pota,tino ka age 140 years.pota jitne month ka dada utne saal ka,pota jitne din ka baap utne week ka,tino ka age kya hoga?
Hahahaha, Aaala! Kafi sochna para, is tarha ho ga mere khyaal se;
140 Saal teenoN ki mila k banti hay;
Pota: 7Years
Baap: 49Years
Dada: 84Years
7+49+84 = 140 (Theek)
Pota kitnay Month ka = 7 x 12 = 84 => Dada ki umer in years (Theek)
Pota kitnay Din ka = 7 x 365 = 2555din => Baap ki umer in weeks [ (49x365) / 7 ] = 2555 (Ye be Theek)
Concerned, Nooh bin Sikander
Dec 18, 2010 | Computers & Internet
I'm 65kgs weight,height 5'3'' inchs,age 25.i want to reduce weight upto 10kgs using treadmill at home....can u tell me dait and work out for best results......
If your unit has a interval training mode I suggest you us it. Frequency of training should be no more than 20 to 30 min 3 times a week because you want to loose approx 1 pound ( .5 kilos ) a week, the first 10 days you will loose 2.5 to 5 kilos just because of water weight then you will grind out the 5 to 7.5 kilos. Before doing any thing drink 2 glasses of water this will increase your metabolic rate then do your training first thing in the morning. By using this formula Heart rate minus age times .65 this sould be where target heart should stay low intensity work out will burn body fat and not burn you out. Go to this website www.webmd.com and more information to keep you on path of healthy living. Good Luck!!
May 05, 2010 | Exercise & Fitness
I WAS ON YESTERDAY WITH THE SAME APPLIANCE A JENN AIR REFRIGERATOR JCD2389GEB. I NEED TO START AT THE BEGINNING. EVERY COUPLE OF WEEKS MY REFRIGERATOR ON TH ICE BOX SIDE WOULD GET WARM THE FREEZER WAS...
What you started out with was a defrost issue,adding freon made your problem worse,pressure on the low side when fully charged should be around 0 to 3 lbs.
 the most common problem with theses units is the adaptive defrost control sits in the refrigerator section top right corner above the white plastic cover.part # 61005988 runs about $70.
 Second most common defrost issue is the defrost thermostat # 61006199 runs around $45 comes wired in with the heater assy sits behind the wall in the back of the freezer. But first you need to get someone to evacuate the system and put in the right charge it will be on the model number tag on the ceiling of the fridge it's somewhere between 4 and 6 onces not pounds.
Sep 23, 2009 | Refrigerators
93 Celica getting Hot
Sounds like your water pump may be going out.If the fan is mounted on the water pump,grab the fan on each side and try to wiggle it.If it moves side to side any its bad.
Jul 11, 2008 | 1993 Toyota Celica
Plumbing Logo
32 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
