Question about Frigidaire FAA068P7A Air Conditioner
Hi, my Frigidaire AC (FAA068P7A) unit was working fine last year. Put it back in the window today and now it won't power on. I checked the power cord, but cord is fine (I actually opened up the machine and detached the cord and tested it). Any other possibilities?
    Novelist:
    Champion:
  • 246 Answers
Sounds like a breaker has tripped (caused by the unit) or is it might just be 'off' for some reason. I would check the outlet (where the AC plugs in at).
If the AC is a 110V unit you can check the outlet by plugging in something else, i.e. a hairdryer. If the hairdryer doesn't work either - then you know your breaker is tripped. On the other hand if the hairdryer 'works' then you know the problem is in the unit, where I'm afraid you'd be better off to have a technician to trouble-shoot it, although you could try sending additional information at this point for more help.
Remember if it is a breaker tripped - it was probably tripped by a malfunctioning Air Conditioner so if it 'trips' again in the immediate future you will need someone to check it out.
good luck!
Posted on May 04, 2010
The display is only showing one out of the two digit temperature setting. How can I fit it?
window air conditioners are great for cooling a room and even to take the heat out of a house. I have done it for years now here in Florida and have central air but rarely run it like today it is about 90 and I have only one window unit running and it does a great job. When It goes out I will go to Wal-mart and spend about 150 buck and just buy a new unit, ( maybe less) get the 5000 btu if you can. What I am trying to say is don't bother fixing that unit, they are a throw away item.
May 29, 2015 | Frigidaire FAA068P7A Air Conditioner
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I have a frigidare ac window unit 6000 btu getting a fine mist blowing out of vents its still cool and works fine but whats causeing the mist ty in advance.
I am getting that too today... nothing wrong, just a very. very humid day....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 07, 2011 | Frigidaire Heating & Cooling
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
I purchase this aircondtioner at Bestbuy in August 2010. I use it for maybe a month. I live in Connecticut so you only need an Aircondioner June thru September when it is hot. I turned my aircondioner on...
Hello, if the unit is blowing warm air it could be due to 1) low airflow due to dirty air filter or evapoartor coil 2) low refrigerant charge 3) compressor is not engaging. check the filter first an let me know if it is clean
Jun 08, 2011 | Frigidaire FAA068P7A Air Conditioner
Compressor wont come on
Check thermostat. Compressor relay. Compressor capacitor.
May 27, 2010 | Frigidaire FAA068P7A Air Conditioner
No power
change the plug the GFI goes bad in those all the time that should solve the problem
Apr 08, 2010 | Frigidaire FAA068P7A Air Conditioner
Frigidaire FAA068P7A Air Conditioner Logo
359 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
