Question about Intermatic & Indoor/Outdoor Rain Tight Timer
How to wire 220v line side - Intermatic & Indoor/Outdoor Rain Tight Timer
  • 10,865 Answers
Hello. There is actually a wiring diagram in the lid of your timer. With 220V you actually have two hot wires, each with 110 V. One hot wire is black and the other is red. Attach one hot wire to line 1 and the other to line 2. Joe
Posted on May 03, 2010
How to wire air compressor motor to 220v
Insulate brown means cap and tape.
240Volt should not have neutral wire
http://waterheatertimer.org/Basic-house-wiring.html#basic-wire
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
240Volt coming from breaker box will have 2 hot wires... and either hot wire is same no matter wire color
http://waterheatertimer.org/Color-codewire.html#motor
Gene
Oct 07, 2014 | Hardware & Accessories
I have a 220V circuit (1 black wire, 1 white wire, and one green ground wire. The new stark industries pool pump has three terminals plus a ground, There is one terminal for a black wire (terminal A) and...
First, be absolutely sure that your motor is wired for 220v. If it is 110v and you apply 220v the motor will die instantly (after a loud bang). Also verify that your supply is in fact 220v.
Without exception 220v power should be supplied by two wires of the same color, as they are both "hot". Black and white wires are common in 110v wiring, the black being hot and the white neutral.
Every pool pump I have worked on has had two terminals where the wires attach to the motor, L1 and L2, wire orientation does not matter.
Evidently yours only has one. Apparently there is no wiring diagram on the side of the motor either, which is also atypical. Best bet is to call the factory for assistance with this.
Dec 22, 2013 | Pool & Spa
Wire a 220v heater to a transformer, contactor, and thermostat
one side of transformer secondary to one side of contactor coil. the other side of transformer secondary thru t stat to other side of contactor coil. line voltage 220v to l1, l2 of contactor . other side of contactor to load (220v heater. ) Make sure heater has some sort of overload /overheat safety either breaking line voltage or control voltage 24v.
Nov 27, 2013 | Heating & Cooling
Wiring a AOSMITH S48A93A66 FAN MOTOR FOR 110
Motor wiring will appear on label on side of motor, for Lo 110V, and Hi 220V.
L1 is Line 1 is usually Hot wire
L2 is Line 2 is usually Neutral wire
Motor will show direction of rotation CW clockwise.
Compare diagram with old blower motor.
http://www.centuryelectricmotor.com/Applications/AdvanceCatalogSearch.aspx#Blower%20Units
Take photo of label and include link to photo so wiring diagram can be viewed.
Nov 08, 2012 | Pool & Spa
How do i wire the back panel on my dryer
if your asking how to put on a 220v line on? if you are, all you need to know that the middle wire needs to be in the middle. the outter wires can be put on either side.
Jan 10, 2011 | Dryers
All our our Panasonic Split Type air conditioners in our plant do not operate when power source is taken from a power generator set but the Carrier brands operates well. What could be the reason for this...
The genset power most likely is 220V line to ground power. You utility power is 220V line to line but uses 2ea 110 VAC line inputs to get that 220VAC. The only way to correct this is to reconfigure your generator connection to 220V line to line IF possible. Some generators that only have a 220V output. Re-configuration is not possible
Measure power at the breaker on gen power as the source and again with the utility as the source. You will see the difference in voltages. Utility power.... each side of the Breaker output to ground = 110V across the 2 terminals 220V
Gen power one side of the breaker output = 220V other side = ZERO.
You can make it work but it would take some heavy duty relays in a power sub paenl so that when the generator is running one side of the power is 220V and the other side is Ground. Once utility power is restored the relays would disengage and power would again be 220 VAC line to line.
You will need a licensed electrician and a PERMIT to install a relay panel such as I mentioned above. Improper wiring of the power relay swtitching panel can cause major power problems in any given installation and trip the MAIN PWR breaker.
Thanks for choosing FixYa.
Kelly
Sep 05, 2010 | Panasonic Heating & Cooling
Motor is hooked up correctly according to directions Green ground, white nutral, red,high speed and black low speed. This motor was the replacement for a cal spa hot tub. The motor does not run on high...
You have 220v running into your motor, the red and the plack are in most cases the same 110v line and what your calling a white netural is a common line. In other words the second half of your 220v line. If your red and black are the two opposing 110v lines that make up your 220v and they are put on the motor and turned on they short aginst each other and blow the breaker. One of your 220v lines should come into your hi -low switch and then split to your high and low on the pump. The other half of your 220v line will go to the common or what your calling nuteral. The difference is a netural completes a 110v circut and a common completes the 220v circut it will take to run the motor. One of the splits will complete the low speed circut and the other will complete the high speed circut. You need to check your voltage comming into the spa, the way the spa is wired (110v-220v), and how the motor is wired (110v-220v). For your spa this will be in your owners manuel or on a scematic inside a panel or door and is quite often a plug you change from one spot to another. On your motor will have a scematic on the back of the motor that will tell you haw to adjust the wireing already in place on the wire board of the motor. This may sound deep but if all your voltages are set the same and your high and low are the same leg of power, this should fix your problem.
Oct 30, 2009 | Pool & Spa
Wire an AC fan motor
Look at the schematic on the new motor , but i think if the 2 purple wires go each one to each side of the capacitor, the black to line and you need to connect the other line which Im 99% sure is the whte wire which is the only one left.Remember you need 220v between the fan motor lines for it to work.
Sep 30, 2009 | Carrier 38CKC036 Air Conditioner
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
I have 3 wires how do I wire the Wayne Reliant one swimming pool pump?
You should have a wire diagrahm on the back of the motor. It will give you placement for your lines and how to wire it for 110v and 220v. In ether case two of the wires will go to the line connections. You should have one green wire that will connect to the motor caseing on a green screw. It will be out of the way and not on the wire board. It will be on the motor housing off to the side. I hope this helps.
Jul 14, 2009 | Pool & Spa
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
304 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
