Backlight on my emachine flickers on and off.
  • 57 Answers
It seems that there is some loose connection from the hinges so contact emachines nad get it repaired
Posted on May 03, 2010
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
Emachine backlight or inverter. How to replace it.
I suggest visiting a specialist and not doing this by your own.
Nov 26, 2011 | eMachines Computers & Internet
Why does only 1/2 of my monitor screen flicker. Left side only
You have one CCFL backlight or half of the inverter failing. My bet is on the inverter.
Dec 09, 2009 | E-Machines eMachines Monitor E15T4
Monitor blacks out
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 12, 2009 | E-Machines eMachines Monitor E15T4
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Olevia 237V Backlight problems
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Backlight flickering
Matrix. Backlight lamp is flicking, you shoud change the matrix. If it is in guarantee, that is not you priblem, but if it is not..... the cheapest way is to find someone to chenge just the lamp. if you can
Apr 28, 2009 | Acer TravelMate 5720-6635 Notebook
Flickers and goes black
No it is not a backlight it is the inverter board which sends power to the backlight most likely cause is bad capacitors on the inverter board. this wil require soldering to repair backlight is even worse it requires you to disassemble the lcd unit. if you are gong to ope up the lcd monitor look on all pcb boards for deformed (blown) capacitors replace those with identical ones from yur electronics shop9they must be exactly the same mfd (Microfaradays) and Voltages
Mar 02, 2008 | Hyundai ImageQuest L50S 15" LCD Monitor
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
