Question about JVC AV-27320 27" TV
What are the best picture settings for a JVC AV-27320 27" TV
techman
  • 3130 Answers
SOURCE: dead jvc tv,av-27320
There is most likely the main power supply has several shorted parts in it, depending on how old it is, it might be worth at least an estimate. if you have homeowners insurance, you may want to concider reporting this to them. Good Luck
Posted on Apr 06, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Low zzzzzzz sound
There are many transformers and coils in use inside the TV. These are coils of wire wrapped around a central core. Sometimes, especially in the yoke or horizontal linearity coil, the core will "sing", making a noise from the back of the set. This is normal, but if it is too annoying then the part making the noise will have to be replaced, and that should be done by a qualified tech.
Posted on Aug 21, 2007
  • 275 Answers
SOURCE: jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Posted on Dec 01, 2008
SOURCE: Picture on tv JVC 27" AV-27530 is getting to dark
I have the AV-27S33 model and in the rear to the right of the inputs are two slits and inside these slits are two screws. The top screw is the focus,the bottom the brightness.Your tv is a different model but it may have this same adjustment,if it does try turning the bottom screw to the right to increase the brightness.
Posted on Jul 11, 2010
gopakumarg43
  • 75404 Answers
SOURCE: i have no picture on my JVC AV-27730 tv. Where is
Hello
Picture tubes are available at electronic spare part shops. You have to give them the number and type of the picture tube, to which your JVC TV has. Picture tube, along with its Yoke fittings are integrated, and you can replace it by yoursef at home. Be very carfull in handling the picture tube, as they are highly vacumed, and will explde by hard hits. There will be four seating screws on the four corners of the picture tube, and these slots will clearly alaign if the picture tube selected is orginal number. Diamentions of these holes will be different to spherical and flat picture tubes. So you must first aware of the type of picture tube, which the TV has fitted earlier. OK.
Posted on Mar 06, 2011
I have a jvc lcd colour tv lt32d21 model 2010 with a jvc remote. i also have a foxtel iq set top box with foxtel remote.
It will be best for you to download the user manual to your TV. www.retrevo.com/
Check this site to download it for free. It has all details. Electro help
Oct 23, 2014 | JVC AV-32260 32" TV
JVC AV-27S33 only displays black and white (Color gone) Menus are still in color!
Check its color system adjustments. It will be best to make a factory reset to this set. Just unplug the TV from AC mains wall socket, and re-plug it after 10 minutes of so. This must make your TV a hard reset. If this do not help you, the chroma section circuits of your TV need to be checked for fault/s. This is a skilled work, and it will be best to contact any experienced service technician.
Jul 04, 2012 | JVC AV-27S33 27" TV
Im trying to hook up a HD A/V combo cable to my led jvc and the tvs missing one connect part. Im only gettinf black and white but the guy insisted that it was the right cord. What cord do I need?
You don't need a ikonvert box if you tv has a AV out (monitor out on picture) then all you need is an AV cord sorry if this is not helpful
May 25, 2012 | JVC Televison & Video
Jvc hd 52g787 my position adjustment in my menu will not highlight so i can adjust picture over to the left. help please
Hello
Just make the picture status button on the remote control and get the display setting to its factory mode.
The VIDEO STATUS button gives you a choice of three TV picture display settings, including a
display of your own preferences.
Standard - Resets the picture display to the factory settings.
Dynamic - Heightens contrast.
Theater - Gives a rich, film-like look to video. (AV-27D303, AV-27D203 and AV-20D303 only)
Sports - When you watch a sports program. (AV-27330, AV-27320 and AV-27S33 only)
Press the VIDEO STATUS button repetedly to get these choices.
Aug 13, 2011 | JVC AV-27750 27" TV
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
Jvc av-32wf35 Lost The Picture
that is what we call a "frame colapse"
the frame ic on the set can blowin.
did you have any power failuers beforthis happend.
May 11, 2009 | JVC AV-32WF35 TV
JVC AV-48WP30 Problem
the best place for parts with free installation instructions is the following link. In fact its the only place that I am aware of that send s instructions with their parts.
http://servicemanuals.vstore.ca/
Apr 21, 2009 | JVC AV-48WP30 48" Rear Projection...
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Dec 09, 2008 | JVC AV-36950 TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
JVC AV-27320 27" TV Logo
56 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
