Question about Vizio VW42LF 42 in. LCD HDTV
Our vizio picture has gone black, but we do have sound
  • 3 more comments
  • Angela Ford May 03, 2010
    This has happen once but we turn the TV off and the screen came on
  • Angela Ford May 04, 2010
    Where would you find some oneto work on the VIZIO
    How does the back come off we have all the screws out still can't get the back off
    After we get inside where do we buy the part
    Which board is the inverter board?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 03, 2010
  • Rylee Smith
    Rylee Smith May 03, 2010
    Yeah right, it seems to be a bad component on the inverter board. You can open the back of the unit then blow off the air and check for the inverter circuit board. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Dusting it out real good will make it work again, be careful not to touch the circuit boards with metal objects. I used a shop vac with a bristle brush, nice
Posted on May 30, 2010
Vizio tv no sound or picture?
Could be the capacitors going or have gone out. This is a common problem with Vizio TVs...including mine recently. Check out YouTube for tutorials on how to change the capacitors.
May 09, 2016 | Vizio Televison & Video
Vizio 55" M550NV turns on, screen displays Vizio symbol for a few seconds then turns black but the tv stays on. What is this and how can I fix it?!
Hi Tiffany, The link below is a YouTube video showing how to fix a Vizio television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
Vizio Tv With No Picture Good Sound YouTube
May 07, 2016 | Vizio Televison & Video
TV has no picture, no sound just the VIZIO logo light is on the screen.
Did you check out the power supply for proper operation since both the audio and video are gone? If PS is good then the problem may very well be on main board.
May 03, 2016 | Vizio E421VA 42 in. LCD TV
May have had a power surge. Now Visio light comes on, but no sound and black screen. Can it be fixed or too far gone?
Not 'too far gone' yet but the nature of the failure points to the modular switched mode power supply,
Look for a block assembly with larger components and several connectors that is bolted onto a larger panel.
These are purchased from other sources, not made by Vizio.
Look into the guts of this assembly for cylindrical components with plastic foil and an aluminum top, mostly mounted vertical to the board.
Examine the tops of these for any dome-like appearance; this is a sign of failure since these should be flat.
They are inexpensive (one reason they fail) and this failure can be prevented by spending another dollar or two in the manufacture of them.
Dec 19, 2014 | Vizio 55-inch E550VL 1080p 120Hz LCD...
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio VP50 has sound no picture
If this is an LCD TV, show a flashlight on the screen from a safe distance and check whether you can see the picture. If you can, the backlights or its circuits have gone bad. If you cannot, the TV needs attention of a qualified service technician.
Aug 12, 2012 | Televison & Video
Vizio L37HDTV10a, No picture, Sound works fine.
maybe its the Y or X Sustain its depends on your picture
Feb 09, 2010 | Vizio L37 Television
Have a 42 inch vizio lcd has two black lines halfway down the screen that after awhile disappear then reappear had three lines one is gone completely ,curious approx cost to fix is it an easy fix or junk ?
HI I HAD THIS ON MY SONY YOU WILL FIND IT IS AN ELECTRICAL APPLIANCE CLOSE TO TELLY IE WII AIRFRESHENERIN 13AMP SOCKET BROADBAND TRANSMITTER SWITCH ALL OFF AND WAIT ADAY CHEERS
Oct 25, 2009 | Vizio GV42L 42 in. LCD Television
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
Vizio VW42LF 42 in. LCD HDTV Logo
222 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
