Question about HP 190 Copier
What type of connection cord do you use to connect this copier to my computer? the only thing i see on the back of this computer is a coaxil port if this is it.where can i purchase the cabel,via enternet or store
  • billyandpat May 04, 2010
    i really need to know how to connect hp 190 color copier to my pc. i don't see a usb port only a coaxil plug in in the back of the copier
    thanks yo kow this usb slot was covered up in the back used a steak knife to remove cover if any one else has this problem thios might come in handy
  • 15,935 Answers
There should be a USB port.
Its not a traditional USB flat slot - its a square one with a rounded top (so you have to buy a SPECIAL cable.
Its the one in the middle.
Thanks!
Posted on May 04, 2010
    Genius:
  • 1,417 Answers
Hello
there two types of cord that are you in connecting up order in to the computer depending on the type of your system
but bass on what you have mention above what you need for your connection is call SERIAL CORD OR WIRE while the other cord is also call USB CORD
for the purchase of this cord were you can buy this cord on net or in there store and it will be in the original form that am very sure no matter well you are station you will sure get it from them in a very time
is www.shopright .com
Good luck and thanks for using fixya
Posted on May 03, 2010
The port to which the printer is connected is not supported. Check the port
I'm assuming you are using a USB connection, not a Ethernet connection.
Try a different USB port (preferably in the REAR of the computer, not the front). It's not unusual to have 1 or 2 poorly-performing (low power) ports on a PC; some printers don't like those.
If you have a really old computer, it may have ancient USB type "1" (slow) ports instead of the newer 2.0 or 3.0 USB type. Some printers don't like old USB 1 ports, but it is not supposed to matter.
If all else fails, try another USB cord, or a shorter one. Some printers don't work well with cords longer than 4 feet, and USB cords can go bad.
Or, try the printer on another computer. If the same USB cord works fine there, YOUR computer has the problem (probably a USB port or USB driver issue).
Are you having issues with other USB devices? If so, it may be a Windows driver issue.
Good luck. If no help, post your exact printer model # here, or try contacting Lexmark.com support
Dec 02, 2013 | Lexmark All-in-One Printer with PictBridge
What cord do I need to connect my 1810 gateway monitor to my tower
Your either going to need VGA or DVI. You need to check the back of your computer and monitor to see which type of connection you have. Then plug in the appropriate cable.
Pic of VGA cable: http://www.ccrzone.com/attachments/Image/VGA_M-M_6_.jpg
Pic of DVI cable: http://farm4.static.flickr.com/3216/2995518986_9deb622bff_o.jpg
Jul 19, 2011 | Gateway FPD1810 18.1" LCD Monitor
I recently purchased a new pc hp2009m and the cord on my lexmark e250dn does not fit my pc how can i adapt please advise. Colin
This printer has three standard ports: bi-directional parallel, USB, and ethernet (RJ-45). Most likely your previous computer had a parallel port. The simplest solution is to get a USB cable (Male type A to Male type B - 6' or less in length is recommended.) Install the software on the computer then connect the cable to the port on the back of the printer and to the computer (the square end goes to the printer and the rectangle fits the computer). The USB port is in the same area on the left side of the back of the printer as the parallel port.
Alternatively you could get a network switch and connect the printer as a networked printer. The ethernet port is near the middle of the back of the printer.
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_E250D&segment=DOWNLOAD&userlocale=EN_US#1 has the software and drivers for support OS versions.
I hope this helps.
(Getting a bidirectional parallel to USB adapter is cludgy when you have a USB port available.)
Jul 01, 2010 | Lexmark E250dn Laser Printer
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
I am unable to "enable bidirectional communication" with my AIO 966
Is it connected via a parallel port? If so, then you need to change the parallel port type in your computer's BIOS Setup to EPP or ECP type; Windows will register the new port type and you should be able to establish a bi-di connection.
BTW, does it not work without this bi-directional connection? The only thing you lose is some fancy stuff like ink levels monitoring etc.
Oct 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell photo ai0 924 what type of cord do I use to
You would need a standard USB printer cable to connect your printer to your computer. It is readily available at any radio shack near you. Refer to the following image to see how the ports at the cable would look like:
Thanks,
Abhishek
Sep 25, 2009 | Dell 924 All-in-One InkJet Printer
Hp laserjet 4001n
The cable you need to connect to your pc is a regular parallel cable. It is called, IEEE 1284 Bi-directional Parallel Cable.
If you intend to use the a USB port this is what you need; USB to DB-25. The printer connection of the cable is the same the only diffrence here is the USB female adapter for the pc.
Nov 14, 2008 | HP LaserJet 4100n Printer
Printer connection to dell computer
the usb port on the front is for camera down loads. There is a printer port on the back by the power cord ( kinda square looking) the other end of the printer cable is the typical usb connection. This goes to the computer
May 18, 2008 | Lexmark P315 InkJet Photo Printer
HP 190 Copier Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
