Question about Royal Sovereign Portable Air Conditioner
Model arp-900e wont start keeps popping breaker
Model arp-900e wont start keeps popping breaker on plug
  • 674 Answers
Sounds like you have a short or a groud in a fan motor or compressor motor. You can unhook one component at a time and turn it on after each component is disconnected to figure out which one is grounded.
Posted on May 03, 2010
Keeps blowing circuit breaker
It could be the circuit breaker, those do sometimes go bad, but it could certainly be something plugged into that circuit pulling more current than it should. Try disconnecting everything on that circuit. Does the breaker still pop? No? Plug one thing in. Pop? If not, keep going until you find the one that's a problem, and check the total amount of current all the devices you have plugged in use.
Most standard plug circuits are only rated at 15 amps. For example, a toaster may pull 12, a hair dryer 10. You can't run both at the same time on one circuit.
Jul 10, 2015 | Electrical Supplies
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Have tried multiple outlets but the unit doesnt turn on
Try draining the unit. If the drain pan is full, the unit won't turn on.
Sep 29, 2010 | Sovereign ARP-900E Air Conditioner
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Water full
Your not saying what brand or model you have but it sounds like you don't have the right drain system
Sep 26, 2008 | Sovereign Heating & Cooling
Royal Sovereign Portable Air Conditioner Logo
191 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
