Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
For dummies my modem is a smartax mt880 and i do not know how to connect it to my computer
    Brigadier General:
  • 6,966 Answers
Connecting a SmartAX MT880 to your PC is straight forward.
1. Connect your ADSL line from the telephone line splitter to the rear of the modem marked ADSL;
2. use the provided straight-through Ethernet cable and connect one end to the Ethernet port of the mode, connect the other end to the LAN port of your PC;
3. connect the provided 9VAC adapter to the wall outlet and the plug to to the jack marked 9V AC 1A;
4. power up the modem by switching it on using the rear panel power switch;
5. on switching on the modem, the Power led indicator in the front panel should lit up;
6. the ADSL Link & Act leds should blink while negotiating with your provider. Upon connection, the Link led should have a steady light and the Act will blink when you are uploading or downloading;
7. on the LAN leds, the Link should have a steady light if connected to your PC. The Act led will blink if your PC is sending or receiving from the Internet through the modem.
8. Prerequisites are: an active 2-wire/telephone ADSL account, LAN card in your PC, appropriate Operating System, and all the accessories that came with the box of the modem.
Should you be in need of a copy of the manual, it is available here. Upon download, pls add ".pdf" to file name to be viewable in Abobe Acrobat reader.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 26, 2008
  • Louie  Role
    Louie Role Mar 26, 2008
    Ooops, sorry guys for doubling up. Cheers.
    Master:
  • 351 Answers
Dear Akhwand,
SmartAX MT880
Quick Installation Guide. Use this Quick Installation Guide to quickly establish your ADSL connection.
www.huawei.com/products/terminal/pdf/view.do?f=352&ctype=0
Cheerup and Be Happy Always
    Scholar:
  • 89 Answers
Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter 192.168.1.1. This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
SmartAX MT880 driver
The SmartAX MT880 is a Router and does not require drivers to access.
Access to the Router can be done by type the I.P address of the Router in a browser e.g Internet Explore
To find the I.P address of the Router.
From a Windows PC connected to the SmartAX MT880 via a network cable,
Click the Start Menu, Click Run (On Vista and 7 you can type run in the search bar)
From with-in Run, Type cmd, Click Ok
Once the Command prompt windows appears, type Ipconfig /all with the window.
From the list of information find the line called Default Gateway (most like under Ethernet adapter Local Area Connection) a example is provide below.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IPv4 Address. . . . . . . . . . . : 192.168.1.13
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
In this example the I.P address of the router is 192.168.1.1.
Oct 27, 2011 | Microsoft Windows Vista Ultimate Edition
How to configure Huwaei MT880 with linksys WRT120N router?
Try these steps:
  1. Shut down the DSL/Cable modem
  1. Power up the router (no cables just yet).
  1. Power up the modem and wait for the appropriate lights (power, ethernet, and activity – something along these lines)
  1. Connect the modem and router with an ethernet cable (if there is a WAN port on the router make sure to put the cable in this port).
  1. Connect Port 1 on the router to the network card on the computer using an ethernet cable and check to see there is a light at the correct port.
  1. Open a web browser, such as Internet Explorer or Firefox. Input your routers id (usually an IP address or an URL) in the browsers address bar and press Enter. The address bar is where you would normally see, for example, http://www.google.ca If you don't know the IP address (such as 192.168.1.1) or the URL, try going to the manufacturers web site and downloading a manual.
  1. Now, a window will open asking for a user name and password (these are given to you in the instructions of the router). For example, Dlink sets up some of their routers as, username: admin and leave the password field blank then press OK.
  1. Now you are in the configuration page of your router (wireless most probably). Here you can set the encryption, new passwords etc… If your not comfortable doing these on your own most routers have a wizard that you can follow.
  1. If everything goes alright and the settings are successful you can now try the wireless connection. Go to a machine with a wireless card, right
  1. At the computer with the wireless connection, make sure the connection is on You might be trying to connect to the network by using either the application that came with the router or windows wireless configuration. Right click the icon in the system tray and “view available networks”. If it comes up in a window saying “Windows is not setup for wireless networks” then you must right click on the correct icon in the tray.
  2. Now, in the list of available networks, click on the name of your network Click on "connect" and it should ask for your security id (the encryption code). Put in the code (usually twice) and click connect or OK. It should now be "acquiring anip address" and in a few minutes it should be connected.
Nov 01, 2009 | Linksys Wireless-G Broadband Router
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id mehtaankur3@gmail.com
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
How do I connect a MaxG wireless router into a SmartAX MT880 DSL modem
  • Connect cable from router to computer ...
  • Connect cable from router (internet port) to the modem ....
  • U will be able to go online ....
  • And after it is done ...u can do the wireless settings ....
  • then connect to network and u will be perfectly able to go online ....
Oct 24, 2008 | U.S. Robotics (USR8054) Router
Change modem from Bridge to Router
Have you tried the default wich is admin for both username and password field?
Jul 30, 2008 | Computers & Internet
ADSL Modem Huawei SmartAX MT841 USB driver not supporting Window Vista Name update of Vista
Hi!
Do not use the usb port or cable. use the RJ 45 port instead. and configure PPPoE and connect using UTP / STP cable with RJ 45 connector straight crimped.
Jul 27, 2008 | Computers & Internet
SmartAX MT882 Firmware Problem
Hi there!
I'll try and help you out with this but I need to ask you these:
1. Is the firmware of the MT880 compatible with the MT882? Have you checked their website for the correct firmware for the MT882?
2. Do you know how to access the routers web ui? If Yes, then try to go to Tools > Firmware Upgrade
Hope this helps!
Sep 12, 2007 | Computers & Internet
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
303 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
