Question about Bosch SHE4AM02UC 24 in. Built-in Dishwasher
Diswasher not draining
Dishwasher not draining
bunch of water at the bottom
took filter out and swished water around in the hole, but water still not draining
  • 901 Answers
Check main drain pipe.
Posted on May 04, 2010
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
Maytag Diswasher DOP Model MDB6600AWW Serial 15365054LE Water sits in bottom of dishwasher Dishes not clean Don't know how to get filter off to clean
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 25, 2011 | Maytag Dishwashers
Miele G646SC Plus dishwasher Drainage / inlet warning light
If the unit doesn't drain properly check for any kinked hoses and also check the drain spigot under the sink where the drain hose goes into the sink as these are not always opened up enough for the water to escape and a slight shoulder can then trap food particles and cause a blockage.
As for the base tray getting water inside the unit check inside the cabinet to make sure the top spray arm lock nut is tight and the ring on the side of the unit is not loose inside the cabinet where the water enters the unit. These two things can cause water to run down the side panels and into the base. The black hose i think is the overflow pipe. Also make sure you are not using too much detergent and the correct detergent as this can over sud and water can spill into the base. Hope this helps.
Jan 20, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Maytag Quiet Series 100 Help - diswasher always has water in the bottom - doesn't fully drain. We took apart as far as we could down to the hole with the orange washer _ no obstruction. Put it back...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Sep 26, 2009 | Maytag MDB5100A Dishwasher
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
Miele blinking intake drain light
If you checked the intake water filter and drain filter and still have this problem -- Try this...
1 - You need to take the diswasher out.
2 - Turn it on its side so you can access the bottom panel.
3 - Unscrew the bottom panel
4 - Take off the electric circulation motor (big electric motor with a bunch of hoses going into it (it is the biggest motor -- not the small motor at the front of the machine (this thing actually screws in place from the back of the machine). To take the motor off - just unscrew the bolt from the back of the machine and wiggle the thing out from the seal.
5 - Unscrew the 4 screws (need a one of those special star screw drivers) that hold the motor to the pump mechanism
6 - Turn the wheel to unseize the motor -(it takes very little pressure to do this) and reinstall it -- it will very likely work again (if it does not - you need to replace this motor)
There is apprently an easier way to do this from inside the machine - but meile technicians have a special tool to go in and turn the motor blade to unseize this. It takes very little pressure and I think it would be a crime to pay someone else to do this -- it is so simple....
So, in summary, first check to make sure there are no blockages in the filters - then try this...
good luck!
Aug 08, 2008 | Miele Incognito G818SCVi Built-in...
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Bosch SHE4AM02UC 24 in. Built-in Dishwasher Logo
163 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
