Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Singer Futura CE150 not abl to digitise image
Thank you Yalmer, but I have tried the futura support site, but it is silent on this aspect.
  • 1 more comment
  • mukpisharoty Apr 02, 2008
    Thanks again but my problem does not appear to be due to the driver or Windows Updates. I am bale to operate Futura CE150 through PC for embroidery. The problem is that when I scan a clipart through the editing software, it scans the picture and brings shows the same on the editing software window. But when I save it only the background color is saved. Perhaps I am wrong in assuming that it will automatically convert the clipart into embroidery format (as the advertisement said). The manual and the futura support site is silent about whether it is possible or what kind of editing on the scanned picture is expected from me so that it can convert into embroidery. My basic doubt itself is whether the Editing software of Singer is capable of it or should I buy their Autopunch for the same. If I know this for sure I can buy it, otherwise it will be an avoidable buy. Thank you, Mr. Yalmer, once again for the interest you have taken in finding a solution for my problem.
  • mukpisharoty Apr 04, 2008
    Thank you, Now the position is clear, I have to buy the auto punch. Once again thanks to the forum and all who offered help
  • kaibajam May 11, 2010
    does the number 19 stitch light up, if it does you have it threded wrong.
Hi i am a very new buyer and i would like to buy more software to alow me to do more with my singer ce-150 but what software ?does any of them work with my machine ? or do i have to use the singer software? hope you can help i would like to use my own pictures to send to my macheine
Posted on Oct 12, 2008
Is the embroidery attachment connected while you are trying to straight stitch?
Posted on Sep 09, 2008
I have the Futura CE 150 Singer. It will not let me do ordinary straight sewing. One of the red lights flashes the machine makes two stitches and stops. can anyone tell me what I am doing wrong. Thank you Roberta
Posted on Sep 07, 2008
  • jacquie1105 Aug 24, 2010
    YOu need to refer to the instructional manual in the back. See which red light is blinking on the stitch guide, look in the manual and fix the issue.
    Problem Solver:
  • 5 Answers
For the older Singer models (CE100, CE200) the digitizing software (autopunch) was only included in the 200 series. If they still have this concept I am afraid that you will have to buy the autopunch add on, that was (and most likely still is, since they sell it) the software that converted scanned or pixel graphic into embroidery files. Check if you have the autopunch feature installed (if it still works that way with the new software, choose "create" in the menu, autopunch should appear under a grey line with "design library" and "lettering" the two items above the grey line).
If it is not there (and the new version has not hidden it elsewhere) it is not installed and you will not be able to convert jpg's or bmp's to the embroidery format.
Sincerely yours
Aki
Posted on Apr 02, 2008
  • Akiva
    Akiva Apr 02, 2008
    Another thing: autopunch used to be on a separate CD, not on the CD that had the Futura software on it (at least my CE 200 came with 3 CDs, Futura software, autopunch, and extra designs). Check if it was included in your CE 150 and you just forgot to install it - it would be really a pity to have it double...
    Aki
  • 552 Answers
Here is some info from another user's problem that was posted on fixya.com. Hope it helps. If it does, please let me know and change your rating of this fix. Otherwise, I can try to find more solutions for you.
I just received the latest technical bulletion from Singer on this issue. The fix to the problem is listed below: My system1.gif worked perfect with Hyperfont and Autopunch after completing the process. GOOD LUCK!
REMOVING SECURITY UPDATE1.gif FOR WINDOWS XP KB917422
You must first disable the updates; otherwise as soon as you remove the update and reboot your computer, the update will automatically reload.
To disable the updates:
? Left Click on Start.
? Left Click on Control Panel.
? Left Click on Security1.gif center.
? Left Click on Automatic Updates located at the bottom of the popup screen.
? Select either Notify me but.. .or Turn off Automatic updates. (You may choose the one that you prefer).
? Left Click on OK.
To remove the update:
? Left Click on ADD/REMOVE programs.
? Check (?1) the ?Show Updates? box at the top of the pop-up screen.
? Scroll down and look for ?Security Update for Windows XP (KB917422)?
? Left click on this update.
? Left Click on remove.
? Continue following the prompts such as Next and Finish to remove the update
Posted on Mar 30, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Apr 02, 2008
    You need autopunch according to the singer website.
    I called the toll free number at this sight and when I asked the question about using clipart, I was told you need autopunch feature.
    the website is www.singerco.com.
    There is a phone number at that website under customer support that has someone who can give you the explanation, if you wish to call them.
    Hope this helps.
Blondbird41...
Sometimes when that happens there is a very small piece of thread stuck where your thread runs through the machine... check to make sure thats not the case ... I had that happen to me ...even look on top where the thread runs through....
Posted on Nov 23, 2008
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
Hi please help I just got a singer futura ce150 but it missing stitches on designs and lettering please give me advise what to do. King Regards Coenraad
If you have just got the machine check in the handbook for troubleshooting tips. Also search online "troubleshooting singer futura ce150" .Then choose from the hits returned.
Jul 09, 2015 | Singer Sewing Machines
I have the Singer Futura SES2000. I am trying to install the update on Windows 7. Instructions tell me to browse my computer for the Singer Futura 64bit driver file. Where do I find this file? I have...
I just bought a new Futura CE250 & had the same problem.
I fixed my "can not run an x86 build of this utility on x64 platform" by visiting the futura support website & downloading a service update. I have a computer with Windows 7 installed. There are also updates for Windows Vista & other operating systems as well.
The website is www.futura-support.com
When you are there, click on the link on the left for "Service Updates."
The actual link to where I downloaded my udate is: http://www.futura-support.com/downloads/ce150.html
HAPPY EMBROIDERING!!!!!
Sep 11, 2010 | Singer CE-200 Quantum Futura Computerized...
I CAN'T GET WINDOWS SEVEN TO LOAD THE SOFTWARE COMPLETELY OR FIND THE DRIVER. IT GETS TO THE PLACE WHERE IT ASKS ME IF I WANT TO GO THROUGH THE TUTORIAL BUT THEN NOTHING HAPPENS. IT NEVER SAYS IT IS...
For old models CE100/200/200E Futura software could be upgraded to version 2.5 (ask you Singer supplier), since version 2.5.0.3 windows 7 is supported.
For newer models CE150/250/350 SES1000/2000 software can be updated normally, since version 3.0.0.9 windows 7 is supported.
Mar 29, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE-150 Futura can not locate driver software?
Most probably you have a pc with Windows 7 or Windows Vista/XP 64 bit that are supported since latest Futura software versions. For 64bit support you will need a version 3.0.0.7 and higher, for WIndows 7 support a latest update 3.0.0.9
Feb 20, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Futura CE150 and error 19 keeps popping up but nothing seems to be wrong with the thread or bobbin thread
Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer futura ce150: When I try to run my program on my computer it says failed to initiate security....what does that mean?
It means installation was not completed successfully. You need to uninstall Futura, reboot and install it from the beginning. But before that you need to stop the program that disturbs the installation process. It could be antivirus software or something like that, do not forget to disconnect from the internet before stopping antivirus.
Jan 02, 2010 | Singer CE-100 Futura Computerized Sewing...
Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
Mar 02, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer Futura CE200 Software
If you use the standard FUTURA software. you will have to buy an add-on for the Software.
Singer offers an add-on called Hyperfont which allows to digitize any true type font on the computer.
The software is available in stores and online, but be sure to get the right version for your software. There are versions for the Futura CE150, CE 250 etc, and there are other versions for the CE100 and CE200, so be careful.
You should also keep in mind that although you can digitize any true type font with this software, not every font is suitable for embroidering and will stitch out nicely.
Sincerely yours,
Aki
Apr 01, 2008 | Singer CE-200 Quantum Futura Computerized...
CE150 Editing Software
Go there and check out the support site.It is a singer website.
Mar 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
662 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
