Question about Dryers
My maytag atlantis gas dryer doesnt get hot. - Dryers
  • riza18 May 05, 2010
    it doesnt get hot at all. the model number is mdg7400aww.
    President:
  • 949 Answers
Hi this is Phil, I will help you determine what is causing the no heat situation in your dryer. To make sure I am directing you properly can you send me the complete model number, it will be on a tag that is located just inside the door or possibly on the top of the control panel.
The second thing I would like to ask is if the dryer heats at all or just blows cold air whenever it is on? Some drying problems will heat but not dry and some will not heat at all.
Thanks!
Posted on May 03, 2010
  • Philip May 05, 2010
    Thanks for the information. On this model the most common issue for not drying is the igintor, the ignitor sits behind the front panel. To check for sure, there should be a small plastic square on the lower front left corner. This piece can be taken off by prying with a small flat blade screwdriver.
    When the dryer starts take a look in the window, if you do not see any glow in there after a minute or so the ignitor is bad, if you do then the issue would be related to the coils on the gas valve.
    To replace either you can open the door and remove the screws that go through the hinges and into the front panel, also take the 2 screws off that are opposite these on the other side of the door. The front panel will not pull off from the top and lift off. This will allow you access to the igitor and gas valve.
    Let me know if you have questions.
Mdg8600Aww not heating. Any ideas? (gas line is on)
This tip i wrote about what to check when your gas dryer doesnt help shoild help to seewhy its not heating. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 10, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis gas dryer does not get hot. What should I look at?
check out the ignition spark ignitor
that makes the burner to heat up
Mar 11, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
The dryer does not stay hot
You probably have a restriction in the exhaust somewhere. Check vent to outside , if that is okay remove hose from back of the machine and look for lint buildup in hose and machine. More than likely the problem is in the duct in the front panel where the lint screen goes. To check and clean this you will have to remove the front panel.
Apr 04, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Maytag dryer mdg508daww
sounds like you need to replace the coils on the gas valve. there are 2 of them, they are rond and black
Dec 31, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis doesnt run
change the copasitator this tells the machine to engage the motor
Oct 24, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
