Question about HP DeskJet 9650 InkJet Printer
How do I reset a HP 9650 printer - HP DeskJet 9650 InkJet Printer
  • nyfixitgirl May 11, 2010
    What do you mean? What is the problem with the printer? You can find the User Guide here.
The top of the cradle that holds the black ink cartridge down in place is broken, how do I replace.
Since this is a Deskjet 9650 which mean it is already an obsolete printer. HP might not be manufacturing the parts anymore. Or if they did, it's so much better if you call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts, you can actually get a brand new printer half the price that you will see on the website plus you can also get an extra year of warranty just by adding $1.00 to the total price of the printer.
Feb 07, 2011 | HP DeskJet 9650 InkJet Printer
Both ink lights are on- I changed the cartridges but the printer still wont print. What now?
There is a problem with the back cover of the printer. Try opening the back cover and re-closing it securely. Otherwise, you may have to get a little more MacGyver - see this solution.
Apr 23, 2010 | HP DeskJet 9650 InkJet Printer
The carriage on my HP DeskJet 9650 is stuck on the left side and it makes a whirring sound when you it off and back on. Help!
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 16, 2010 | HP DeskJet 9650 InkJet Printer
SHOWS PAPER JAM AND WILL NOT PRINT
Try reseting it meaning kill the power for an hour or so then re start it plugged in. If nto it is the geas, that are almost impossible to fix.
Aug 11, 2009 | HP DeskJet 9650 InkJet Printer
Windows XP 64bit driver
Go HERE, and select the exact operating system your are using.
Hope this helps.
Aug 03, 2009 | HP DeskJet 9650 InkJet Printer
My computer keep saying my 9650 printer is out of paper but it isn't
Try this:
Connect your printer and power it on. In the flag just cancel it. If it does help, go to printer and faxes, select the printer, then cancel all printing job wait for a moment until it disappear.
If nothing happens for sometime. Feed some paper to it, say 1 piece of paper, reactivate printing job, if print then no follow up paper it will flag again out of paper. Select cancel.
If it still doesn't work switch off and on the printer and repeat the process again.
Hope it helps you
Apr 09, 2009 | HP DeskJet 9650 InkJet Printer
Hp-dj 9650 won't print
please reinstall printer software
Sep 22, 2007 | HP DeskJet 9650 InkJet Printer
Open Questions:
See all HP DeskJet 9650 InkJet Printer Questions
HP DeskJet 9650 InkJet Printer Logo
405 people viewed this question
Seeker5211
Seeker5211
