Question about Dometic Rooftop RV Air Conditioner
Rooftop rv air conditioner doesn't work - what can I check myself without taking the rv to a repair place? will any air conditioner repair place do repairs or do I need to use an rv place?
  • Mike Butler
    Mike Butler May 11, 2010
    Can you give a brief description of what or what not it's doing such as, Fan mode works, but when switched to cool, nothing happens etc...
    Novelist:
    Champion:
  • 246 Answers
I'm assuming when you say 'doesn't work' you mean 'nothing comes on,' i.e. the fan or the compressor.
If that's the case I would check for the AC breaker to see if it's tripped. Usually a 'tripped' breaker will look half on and half off, but sometimes it will be completely in the off positiion. Either way - it's usually because of a malfunction of the AC unit, so if that's the problem I would moniter it closely to see if it trips again. If it trips again in the immediate future I would then want to investigate the AC unit for the cause.
Also, some RV's have fuses in the AC circuit - so you could check and see if you have any fuses labled AC or AC control voltage. If so - you can usually - tell by looking whether they are bad or not. If that's not possible try replacing your 'AC labled fuse' with a new one of the same size.
I would also check your power supply (where the power cord to your RV plugs into) to make sure it is providing the proper voltage to your RV. Note: They also have breakers out on the box that you can reset. If they (breakers) appear ok - and you are at a RV park you could have the Park personel - check and to be sure the proper voltage is availible to your RV.
good luck!
Posted on May 04, 2010
I have an RV which air conditioner has a Domestic thermostat 3105356.004 and is not working properly. Searched the internet and can not find one to buy. Do you have a substitution?
no
this site does not sell anything
take the rv to a caravan shop and have the ac specialist check for an after market unit that will fit
most thermostat are alcohol filled tubes that pushes on a diaphragm that makes or breaks a circuit against a spring tension that is set by the knob
so it is very possible that the ac manufacturer used a common make that will fit but you will have to go to places that retails units such as a caravan repair shop or an ac repair specialist shop
Jun 26, 2016 | Dometic Rooftop RV Air Conditioner
Fan blade
any rv repair place should be able to order it for you
Apr 16, 2014 | Dometic Rooftop RV Air Conditioner
Rooftop ac won't turn on
Check fuse inside RV and check power from thermostat to compressor
May 10, 2012 | Dometic Rooftop RV Air Conditioner
Water coming from ceiling about 3 foot from unit
Does the unit work other, than the leaking?If it does you need to install a square seal between the ac unit and the roof.You can either buy the seal from Ebay or I would recomend an Rv Repair place.(They Might even be able to install it where the Rv Sits)
Aug 05, 2010 | Dometic Rooftop RV Air Conditioner
My rooftop AC RV air conditioner will not start.
You can take a digital meter and put a lead on each
side of capacitor, the meter reading will go up and
then back down, Reverse the leads and it should do
the same thing.
If this is a dual capcitor that controls the fan and
compressor and only the fan comes on, more than
likely it is not the capacitor. However its easier to
replace the capcitor and prey to god that it works.
If it doesn`t then you know you have other issues for
sure, however the capacitor is a pretty cheap part.
Jun 15, 2010 | Dometic Rooftop RV Air Conditioner
Quit blowing cold air
if a leak, should be repairable, a lot of techs these days find it easier and more profitable just to replace things. try a new tech
Sep 04, 2009 | Dometic Rooftop RV Air Conditioner
Where can i get a free estimate fo my rv rooftop air conditioner
Hello Sir.
You can Use our repair directory to locate the nearest Tech to You, take his number and call himm for Estimate!!
http://www.fixya.com/repair/air_conditioners.
PLz Rate.
Jun 17, 2009 | Dometic Rooftop RV Air Conditioner
Have a coleman rooftop unit a/c unit, after about an 1 hr. unit hums no air comes out
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jun 07, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,337 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
