I am getting a dark/black square (rather rectangle) on my display. This is a 65inch rear projection Mitsubishi. This blocks 90% of the TV screen. I can get rid of it if I press on the FORMAT button on the remote. How can I get rid of it permanently? Thanks
    Sergeant:
  • 418 Answers
You have closed captioning, text mode turned on.
Posted on May 03, 2010
Testimonial: "Thank you so much. It's been a big burden on my shoulder thinking it was going to be a component failure. You guys are great."
TV has a beige tinted, rectangle, see through box pop up randomly for a second then goes away, it covers most of the screen any sugestions?
look first in the captions area for TEXT---if its on there will be a blank box in the middle of the screen but usually it will be black--look to see if TEXT is engaged.
Dec 06, 2012 | Mitsubishi WS-65809 65" Rear Projection...
My 65inch mitsubishi tv has sound but no picture what going on?
There is a video reset switch infront of the set, try to reset it.
Feb 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
Mitsubishi tv; black & wht rectangles only on screen.
Bad capacitors and probably a surface-mount fuse on the Formatter board.
There will probably be bad caps on all five boards within the chassis.
Sep 14, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi 1995 cs31205 32 inch tv
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
Oct 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black square on tv screen
Turn off your closed caption...
Bill
Mar 20, 2008 | Televison & Video
Mitsubishi 65 inch rear projection diamond
its the circut board that leads into tv from power cord , i had bought mitsubishi65819 black diamond gray 65inch for $54 ,is under the warranty the board cost $350 , labor $200 but this depends on where u live ,either way it was a steal for me ,but yea i had same problem when u turn tv on it shuts down like not even 2seconds i had tech come out and he had to take the board to get it repaired ,its not available he said but its repairable , was a sears tech so sears can repair it
Oct 29, 2007 | Mitsubishi WS-65869 65" Rear Projection...
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Jul 12, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
