Question about Symantec Norton AntiVirus 2002 8.0 for PC
New folder my pc problem is in this any folder or hard disck part those i'm open there a new folder will be make at 144KB and any dickand folder do't show his reale memory when i'm open this folder opend my document folder please send me it solution on my id WWW.RAJSINGHSAINI03@gmail.com
  • Anonymous Apr 14, 2008
    i tried deleting it
  • 59 Answers
Hello friend
your computer is affected with the viruses you should nstalled the latest updated antivirus and scan the whole system it will remove all these viruses
best of luck
Posted on Mar 29, 2008
TOSHIBA SATRLLITE L655-S5058
What do you mean you can't open files or folders? Are you saying the files or folders are not on the hard drive since it's blank? I think you've got a virus that has hidden your files and folders?
I'm not sure which operating system you have but you need to get to Folder Options.
In Windows XP you can click Start/My Computer. When My Computer Opens click Tools at the top of the window and then select Folder Options. When the Folder Options window opens, click the View Tab and scroll down and select Show All Hidden Files And Folders. Click OK then go click on your C: Local Drive and see if your folders and files are there. Hidden Folders will show up lighter than a normal folder.
Mar 28, 2012 | Computers & Internet
After cleaning the STOREJET 640GB by DoctorWeb, I can see only the separate files on it(which were out of folders).All folders are invisible on any PC.But when I connect it to TV I can see and open any...
Hello that means that your files properties are hidden in your PC. If your operating system is windows 7 you can change it by Clicking START, Control Panel and chose View by Category. Click appearance and personalization and click "show hidden files or folders", located under the "folder option" section. Choose the radio button that corresponds the "SHOW hidden Files, Folders and Drives" option. Uncheck the boxes that correspond to "Hidden protected operating system files". Then save the changes by clicking apply and OK.
If your operating system is Windows XP you change it by clicking My computer then double click the hard drive you want to open then click the view then chose show hidden files and folders.
Keep on touch best regards..
Aug 22, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I installed vista sp 1 in my hp laptop and philips external harddrive was also plugged in and when i finished installing vista sp1 all folders showed E:\liuuv.scr.. i cant open any folders... all folders...
it seems viruses on your hard drive and the extension of viruses is .scr (it hides all files). Try this tips to un hide your files, you must show the hiden files on you pc by following these steps
1.open my computer
2. click on tools
3. click on folder option
4. on the advance setting find the category of hidden files and folder
5.
show choose hidden files and folder
6. click ok
the second step click run (you can find by left click start button )
type cmd
you will be in a command prompt and it will be C:\\
then type the path of your hard drive (for example F:)
after the path show your drive
(for example F:) type attrib -s -h -r -a /s /d
wait until the process finish
now you can see the original file of you with extension file folder not .exe or .scr
you can delete the file with extension .exe and .scr by one left click to the file and press shift and delete button on your keyboard.
don't forget to scan your drive with anti virus
May 23, 2011 | Philips Computers & Internet
My WD 1TB hard disk drive shows me loaded with 300GB capacity of folders but when they are not seen on my pc
1) Open any folder on your your computer and go to: Tools > Folder options > View tab > check "Show hidden files and folders" and uncheck "Hide protected operating system files". 2) Look at your hard disk again, if you still can't see any files on it, there must be an error of your disk. To solve it, go to: My Computer (or Win+E keyboard shortcut) > Right click on the drive representing the 1TB hard disk > Properties > Tools > Check Now... > Check both boxes to fix errors.
Mar 07, 2011 | Western Digital My Book Essential Edition...
My acer aspire 5732z, wont backup disck two, disck one ran fine said error at end of disck two??
That error indicates that your disk is scratched or deformed. Just grab a new cd to continue, or restart the process. Try not to smudge the clear face of your blank cd or it may happen again.
Mar 07, 2010 | Computers & Internet
I bought a refurbished Tungsten E. Because there was some incompatibility with the software version of my other Tungsten (which is on its last leg), I downloaded new software off the internet. In the...
Are you syncing the new device to the same username in Palm Desktop as an older device?
If you are, this will cause problems on the new device. When you sync the device, it saves the device settings, 3rd party apps, preferences, etc. in the backup folder in the username folder on the PC. When
you sync the new device it copies the contents of the backup folder for the old device to the new device. This will cause corruption in the settings for the new device thus causing erratic behavior of the new device.
Looks like you may need to hard reset your device and rename your backup folder
Go to http://www.palm.com/cgi-bin/cso_kbURL.cgi?ID=887 and follow the directions to do a hard reset. Next before you hotsync your data back over you will need to rename your backup folder, to do that go here;
XP
C:\program files\palm or palm one\[hotsync username]\ and rename your backup
folder to backup.old
Vista
Start-->documents\Palm OS Desktop\[hotsync username]\ and rename your backup
Then hotsync to your current hotsync name and all your contacts, calendar,
tasks, and memos will come back over.
Show file extensions for XP or Vista
XP
If you can not view file extensions on your PC I would like you to open a
folder go to Tools-->Folder Options--> View (tab) and under show hidden
files and folders uncheck hide file extensions for known file types.
Vista
Open control Panel go to Folder Options--> View (tab) and under show hidden
Mar 28, 2009 | Palm Computers & Internet
I want to know if you can download movies directly to an external hard drive or do you have to download to your computer and transfer it to the external?
Provided you have an external Hard Drive connected to your computer, you can download directly to it without a problem.
When the save as dialog open, just navigate to the external hard Drive, usually to a Drive Letter E F G ect...
Jan 11, 2009 | Dell Dimension 3000 PC Desktop
Couldn't open the hard Drive folders....
hi sir,
i think you have an autorun.inf file residing at your local drives. this probably infected by a virus.
go to control panel >folder option> click View> choose "Show Hidden Files and Folders" and uncheck Hide Protected Operating System Files, this will show hidden autorun.inf file. In your explorer, right click your local disk and click explore, this will show all your files and folders of your drive, navigate autorun.inf file, if found delete it.
note: it has an associated file called vbsscript file...if found also delete it..do the same with the other drives. empty recycle bin and restart.
Winsor
Sep 02, 2008 | Microsoft Windows Server Standard 2003 for...
My Windows Explorer does not show extentions
By default, file extensions for known file types are hidden in Windows XP. However, you can change this setting so that file extensions are shown for files in a certain folder or for all files on your hard disk.
To show file extensions, first open any folder on your hard drive, such as "My Computer" or "My Documents." Then select "Folder Options..." from the Tools menu as shown below.
545a526.gif When the Folder Options window opens, click the View tab. This will show the file and folder view settings.
95b32b0.gif One of the options under Advanced settings is "Hide extensions for known file types." If this option is checked, uncheck the checkbox and click Apply or OK. This setting is system wide, so unchecking this box will make file extensions appear in all folders.
If you decide to hide file extensions at a later time, you can check the box again and click OK to revert back to the previous settings.
Jul 16, 2008 | Computers & Internet
HP Pavilion dv6000
video driver maby what about redoing windows formatt it all
Jan 18, 2008 | HP Pavilion dv9000z Notebook
Symantec Norton AntiVirus 2002 8.0 for PC Logo
47 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
