Question about Maytag Dependable Clean Top Load Washer, MAV3955EWW
Knocking noise durng spin cycle
My wife tried to wash our king size comforter a few weeks ago and when it tried to start washing there was a high pitch noise like it was jammed. When I lifted the lid, there was a bit of a burning smell.
Since then, it still washes fine but when it hits the spin cycle, there is a knocking noise that gets louder as the cycle completes. It gets so loud by the end that it sounds like someone is hitting the side of the washer. I have tried lifting the lid when this is happening and it looks like the basket is off center.
Have we done major damage to the washer? I took the front cover off and didn't see anything at first glance. The three main springs were all in place.
  • 2 more comments
  • hedgehog2271 Mar 26, 2008
    This washer is a Maytag Dependable Care top load. LAT9634
  • hedgehog2271 Mar 31, 2008
    How do I remove the agitator? Is there a link to a repair guide with pictures that I can read through?
    I removed the agitator (removed the screw inside the basket on the stem and pulled it up). The main shaft appeared to be fine. Hard to tell if it is bent because it is only 3 or 4 inches long.
    I put my hand under the front lip of the machine and could feel the belt and it appeared to have good tension. Do I need to look at it for something in particular?
  • hedgehog2271 Apr 28, 2008
    Well as it turned out, I bought a new washer/dryer because I thought there must be something major wrong with it. When I was pulling out the old washer, I tipped it up so that I could see underneath and I saw that the belt had a spot where it was worn almost halfway through. The knocking noise must have been when that part of the belt made its way around and probably slipped on either the main shaft or the motor. I replaced the belt and it fixed the knocking problem.
    After much debate with my wife, we decided to keep the new washer/dryer.
    Thanks for the help.
    Sergeant:
  • 351 Answers
Remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Posted on Mar 26, 2008
Just want to know the cubic foot load capacity of my kenmore front load washer 592-49047 so I Know if I can wash my king size comforter in it
I wouldn't recommend washing a king size comforter in your machine. That would be ******* it. I take mine to a laundry mat where they have bigger machines.
Mar 25, 2016 | Washing Machines
Kenmore series 80 top loader washing machine 11029852991. When turned on spin cycle, makes a loud grinding kind of noise. I believe unit may have been overloaded with three kingsized bedsheets &...
unless some thing inside the washer is broken i would say the drum bearings have started to wear out badly,,,my washer will easly take 3 king size bed sheets and covers,,,that not a lot realy,,,how old is your unit? and how many washes has it done,,,years old and 1000's of washes?
Jul 16, 2010 | Kenmore Washing Machines
My washer has started making a high-pitched noise while spinning.
Hi
to chek what is wrong follow the bellow instruction....
Check the motor bearings
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer.
Check for Obstructions
Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket.
Check for Grease Spatter
A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing.
Check the Drum for Irregularities
Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Washing Machines
King down comforter
I tried washing a queen size comforter in my washer and blew the boot out of it. 250.00 repair bill. Go to laundymat!
Sep 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Maytag Dependable Clean Top Load Washer, MAV3955EWW Logo
274 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
