Question about Nokia 6111 Cellular Phone
Large hole in screen of phone. Can't view phone info, screen damaged, can this be replaced?
    President:
  • 1,561 Answers
Yes it can be replaced.
Is the screen of your phone broken, if no, it means the only thing you will need to change is the flex on your phone screen.
But if the screen itself is damaged, then you will need to replace the whole screen.
All you need to do is to take it to any local repairer or service center to help with the replacement of your phone screen.
Take care
Posted on May 03, 2010
How do I get a operating "user" manual
I also would like to obtain a user manual for my LG AX265 cell phone. The face/screen on my cell is damaged. It is cracked/broken. I can't see or read it when the phone rings. Or, when a text comes in I can't view the message. All else works fine.
Also, how do I download info from the LG AX265 to a computer or better yet to an external hard drive
Apr 25, 2011 | LG Rumor 2 Cell Phone
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
My Nokia phobe 6085h changed to a blue screen only. I can view absoultle nothing on it. However I'm still able to receive calls and hand dial phone numbers. How can i fix my phone to regain visability to...
Hi,when a phone displays a blue screen,it means that the screen might have shifted from the position it was or the screen might be damaged and will need a replacement.
Unscrew phone and adjust the screen.If no display that means the screen of the phone is damaged and will need to be replaced.
Have a nice day.
Aug 06, 2010 | Nokia 6080 Cellular Phone
Broken screen, who can replace it?
Go to the Sandisk support web site and signup for a Return Material Authorization (RMA) account, you will have to set up an account w/ email address.
Jun 15, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
No display on nokia batter is fine
Hi, when there is no display it means that the screen of the phone in damaged and for you to be able to view your operation on the phone,you will need to replace the screen of the phone.
Take care.
Jun 14, 2010 | Nokia 1100
Hole in wall the size of a fist. How do I fill it and patch?
Follow these steps:
1. Useing a piece of scrap wallboard (same thickness has damaged wall) cut a square piece large enough to cover the hole. Place new piec over the hole and trace around edge of rteplacement piece. Cuit along lines with wallboard keyhole saw so that replacement piece fits perfectly. screw a wallboard screw into center of replacement (to act as a small handle) and coat edges of replacement with joint compound. Fit replacement into damaged hole and trowel compound to as smooth a finish as possible. Allow to dry completely the remove screw and sand to a like new wall.
Feb 24, 2010 | Square Mayes Level 10184 48" Wallboard ...
I sat on my slide up phone and than the screen cracked and now it wont do anything and its a zte slide up phone
What it sounds like has happened, is that you have damaged the internal workings of the screen and maybe the main body of the phone. This is a big problem because in slide phones, much of the electronics needed to run the phone are in the screen area. You probably need to get a new phone, but if you send it to the manufacturer, they maybe able to fix it, but at a presumably large price whether it's in warranty or not. Feel sorry for you, and hope this is enough info for you to make an informed decision.
Feb 10, 2010 | Lands Phones
Nokia 5300
It may have gotten damaged. To replace the screen yourself go to the following site and order the screen:
Nokia Screen
Apr 18, 2009 | Nokia 5300 Grey Cellular Phone
My phone just comes on for a few seconds
When you dropped it you damaged the back-light, now the screen will flash or even eventually go black permanently. There is nothing you can do to actually fix that problem the phone has been damaged.
Your best bet is to take advantage of phone insurance if you have it, if not you will have to replace your phone. When you bring it to the store to replace it they can more than likely transfer over all your contact info even if the screen is flashing.
Sorry about your misfortune. Thank you for trying Fixya!
Mar 23, 2009 | Samsung SGH-D600 Cellular Phone
Fire from top of Microwave
It's not a dangerous or diffcult job for a do-it-yourselfer.
That would be the waveguide cover (also called the stirrer fan cover), and it would need to be replaced to prevent future damage to the magnetron.
Check your model number sticker to get the full model number with suffix and the manufacturer number (PACO1860AB0 for example).
Then you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Good luck and good cooking!
We appreciate your thoughtful rating of our answer.
Nov 11, 2007 | Amana ACO1860 Microwave Oven
Nokia 6111 Cellular Phone Logo
91 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
