Question about Zanussi ZWD1680W Front Load Washer / Dryer
My ZWD1680W stoped half way through a cycle flashed up E20 i draind i t tryed to spin got half way through and went of no power at all NOW
  • 269 Answers
It still seems that something is stuck in the pump causing the machine to do nothing check the filter and pump again whilst the filter is out get a torch and look inside the end of the filter housing,now put the control to spin or drain and see if the pump blade is spinning if not then there is either something stuck in the pump or the pump motor is faulty and needs replacing.
Good luck.
Posted on May 03, 2010
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
I own a zanuusi zwd1680w. washer dryer. The problem is when set to drain or if required to drain during a cycle it goes through the motions and hangsup, the water does seem to drain out quite quickly and...
Hi you dont mention any error codes if there problems with draining e20 is displayed any blockage in the pump or drain passage can cause this . however you suggest the draining is ok so this is more likley to be a fault in the water level control. an easy fix would be if you found a blockage in the pressure chamber at the base of 2 x 8mm tubes(from pressure switches) located near the sump hose at the bottam of the drum. undissolved detergent is normally the culprit.jw
Feb 09, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
ZWD1480W - the cycle will not complete when i programme it for a wash. Half way through the cycle it stops. The drum remains full of half washed clothes and will not even respond to spin or rinse. I have...
Thanks for replying. I was able to solve the problem by clearing the filter and draining the samll tube beside it. I was unaware that the filter needs to be cleared regularly.
Jan 11, 2010 | Zanussi ZWD1480W Front Load Washer / Dryer
Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Nov 04, 2008 | Zanussi ZWD1680W Front Load Washer / Dryer
Too many E20 errors!
the first thing i would try is the pump..........if its not draining all the water out it will take longer to finish...........pump could be blocked......alst the hose from the pump........check both first.....
cheers
Aug 03, 2017 | Zanussi ZWD1680W Front Load Washer / Dryer
Zanussi ZWD1680W Front Load Washer / Dryer Logo
110 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
