Question about Garmin nuvi 250W GPS Receiver
When I turn my device on indoors, it won't pick up a signal. Also, I can be out in the car or in the plain open field and when powering up my device, it always seems to take a very, very, long time to finally find one and most of the time, I have to turn it off and back on again. Why is this and what can I do to fix the problem?
  • 53 Answers
I think the problem is in hardvare.I if it not see or very slowly hardly than there is harvare problems. First need to open the GPS and look at the GPS reciver conector cable. Is it correctly connected to the panel? If no than connect it. Close the case and test it. If yes than you need to delete from the SD card or in the internal memory the "SAVE" directory. There is the settings what the GPS is saving.When it deleted it could find SATELITES more faster (but if you do it you need to set the settings again). If still not working than go to a service. Or you can throw it into the thrass. Sorry 4 my english :)
Posted on Jun 07, 2010
  • 218 Answers
GPS needs to "see" the GPS satellites to work normally. When you are outside the GPS is capable of seeing those satellites. GPS works with something called triangulation principle to get a position fix. Simply put a GPS needs to see at least 3 satellites to work. Even when inside a car, the GPS sees 5 to 8 satellites (or more) at any given time through the windshield and windows. When you go inside a house, GPS would not be capable of seeing enough satellites. And on top of it GPS do not like it, when the SNR (signal to noise ratio) is not at an appropriate level. The program inside the GPS may be in such a way to reject those satellites to give you more accuracy. So GPS goes into a search loop to get more reliable satellites. It is best not to switch on a GPS inside a completely blocked out room. If you have to work on a GPS inside a room, place the GPS near a window and open the curtains. Also make sure there are no trees just outside those windows that completely block out the sky. Once you have acquired some satellites by keeping the GPS on for a few minutes outside in the open and switch it off before you go inside a room, next time onwards yours GPS should acquire a lock much faster.
Posted on May 03, 2010
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
I have a Fredrich 8000btu wall unit model number CPO8F10 and the compressor will not shut off, even when the unit is turned off the compressor keeps running. the only way to shut it off is to unplug...
If your air conditioner or heat pump compressor won't shut off unless you pull the fuses or turn off the circuit breaker. You probably have a stuck contactor. The contactor is the name we give to the big relay that controls your air conditioner, heat pump or other large electrical device. If the indoor blower fan will not shut off either then the problem is NOT the contactor in the outdoor unit but a problem with the thermostat or the wiring to it either at the subbase or the furnace. Before replacing your thermostat you should isolate the cause of the problem or it will persist and drive you nuts. Look for wires touching or cut too long. A contactor or relay is an electrical device that takes a control signal usually 12 volts DC, 24, 120, 208-230 volts ac and creates a magnetic field to pull in a set of contacts that controls another device that may or may not get its electrical power from the same circuit. Note: 99% of most control circuits are 24 volts AC. The contactor has steel contacts that are plated with silver. When the silver wears away you have just plain steel and the steel will weld itself together. Sometimes if you whack the contactor with a screw driver you may free it for a while but the problem will re occur. This problem is especially a problem when a piece of equipment has not been run for a period of time. It is normal for the contactor to wear out over time like brake pads on a car. If the contactor shows any signs of wear it should be replaced as a preventative measure or as part of maintenance. If you suspect a stuck contactor a 100% accurate test is to turn off the power to the indoor section which removes control voltage to the outdoor section and it (outdoor section) keeps running. Do not keep messing with it, your contactor it is bad and you will destroy your compressor if you let it run!!! You can also have problems with spiders building nests in the contactor; the silk is an insulator and will prevent electricity from flowing. Replacing a contactor is a simple matter and they are readily available. Costs vary from about $40 installed to several hundred dollars depending on the size and current carrying capacity. If your compressor does not shut off when it needs to and the indoor fan does you will destroy your compressor. The high and low pressure cut-outs won't work either.
Aug 20, 2011 | Friedrich Heating & Cooling
My Klh r3000 receiver is great for everything except picking up am or fm stations? I had an antenna attached, but the unit is in my basement, and I get no signals at all. What could I be doing wrong?
If the antenna is in a basement that is the problem - the fact that it is below ground means that no signals can get through.
Radio signals are blocked by buildings, large lumps of metal or other solid objects as well as strong magnetic fields (which can include electrical devices within the home).
To pick up good radio reception you will need an external antenna above the ground level - preferably as high as you can get it. Unless you get an omni-directional antenna like this one http://www.maplin.co.uk/vhf-fm-omnidirectional-aerial-874 you will need to point the antenna accurately at the transmitting station (+ or - about 5 degrees) for FM. At a pinch you might get by with an indoor aerial but it needs to be above ground level (inside a roof would be best)
Good external AM Radio aerials are harder to find these days.
Feb 24, 2011 | KLH R3100 Receiver
Cant find wer the spark plugs for a 2001 hyundia sonota
Could be a cover over the spark plugs or plugs have coil on plug system: Ignition System WARNING
To avoid personal injury and/or vehicle damage, refer to the service precautions at the beginning of this section.
General Information NOTE: For information on understanding electricity and troubleshooting electrical circuits, please refer to chassis electrical.
Coil on Plug (COP) System
The coil over plug system was developed so that spark and spark timing could be better controlled on an individual cylinder basis. Each cylinder has an ignition coil mounted directly above the spark plug on the cylinder head cover. A short suppresser/connector replaces the spark plug wire and links the coil to the plug. There are different methods used for primary triggering. Some manufacturers use a combination coil/module, which means each coil has its own control circuit that is activated by the PCM. Others use remote mounted modules to trigger the coils.
Each individual coil is allowed to saturate while all other cylinders fire. For a V-8 engine, this allows a period of seven firing events for coil saturation, compared to three events for the same V-8 engine with a waste spark system. The coil over plug system also benefits from a minimum amount of energy lost, due to the resistance of spark plug wires.
Distributor System
If a distributor is not keyed for installation with only one orientation, it could have been removed and installed improperly and then rewired. The new wiring arrangement would maintain the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes of the current plug wire locations and orientation of the distributor cap.
Magnetic Sensor / Pick-Up Coil
The magnetic sensor in electronic ignition system is made up of a small coil of wire wrapped around an iron core, a permanent magnet and a toothed wheel called a reluctor. These sensors can be found mounted in a distributor, or at the front, middle, or rear of the crankshaft or camshaft, and are two-wire sensors.
The permanent magnet produces a magnetic field that passes thru the center of the pick-up coil. As the reluctor turns, the small teeth enter the magnetic field. Because the metal is a better conductor for the field than the air between the magnet and reluctor, the field strength begins to increase and reaches its maximum when the reluctor teeth are closest to the sensor. An increase in magnetic field induces a positive voltage to the module. As the teeth leave the magnetic field, the decrease in pole strength induces a negative voltage into the module. This alternating positive and negative voltage causes a small AC current. This alternating current after passing through an analog/digital converter is used by the module or engine controller to trigger the primary circuit.
Hall-Effect Device
Another device that can be used to create a triggering signal is a hall-effect device. A hall-effect device can be thought of as a solid-state On/Off switch. The hall-effect switch is a three-wire device that must receive a power and ground. The hall-effect switch is used in conjunction with an interrupter ring with a series of slots or openings cut into it. Depending on the application, these slots are spaced around the ring in a specific configuration. As the ring rotates, the slots pass between the hall-effect switch, and alternately turns the voltage off and on. When a slot aligns with the hall-effect switch, the controller sees voltage on the signal line. When the area between slots passes the hall-effect switch, the signal is pulled low. This results in a voltage of 0V–0.1V at the controller.
The rotation of the interrupter ring causes the signal to toggle, which causes a continual series of digital pulses on the signal line. This digital pulse is the timing signal that is used by the ignition module or engine computer to open and close the primary circuit. The controller processes these pulses as the RPM signal.
Photo-Optical
Another device used to create a triggering signal is the photo optical sensor. Inside the distributor, there are pick-ups called the Reference pick-up and the Sync pick-up. Each pick-up has a Light Emitting Diode (LED) and a phototransistor. A slotted disc rotates between the pick-ups. The pair of LED’s and phototransistors generates crankshaft position and RPM signals (high and low-resolution signals). The LED’s are powered by a 9- or 12-volt source (depending on manufacturer). Each phototransistor is used to turn a 5-volt signal from the engine controller on and off.
If we look at the optical distributor used in the Chrysler 3.0L engine as an example, there are two areas of slots cut into the disc. The outer diameter of the disc, which generates the high-resolution signal, contains 350 slots. Each of these slots represents 1 degree of crankshaft rotation. An area of approximately 3/8" with no slots represents the remaining 10 degrees. The inner portion of the disc is the low-resolution signal and contains six 60-degree slots. Each of these slots represents the piston’s top dead center position for each cylinder. The controller uses the high-resolution signal to regulate spark timing up to 1200 RPM. This ensures timing accuracy, since crankshaft speed fluctuations are most likely to occur because of the firing pulses during cranking and idle. The low-resolution signal is used for injector firing, as well as ignition timing above 1200 RPM.
As the slots pass between the LED’s and the phototransistors, the transistors are toggled on and off. This occurs as the light beams from the LED’s are alternately interrupted. When the light beam from the LED strikes the phototransistor, the transistor turns on. This causes the 5-volt signal to be pulled low (0V–0.1V). When the rotating disc blocks the light beam, the transistor turns off. This causes the 5-volt signal to remain high.
Ignition Coil
The heart of the automotive ignition system is the ignition coil. The ignition coil is a step-up transformer, since it boosts battery voltage to the high voltage that is necessary for proper combustion.
The ignition coil consists of a primary winding and secondary winding wrapped around a soft iron core. The primary winding is made up of several hundred turns of heavy wire, while the secondary winding consists of thousands of turns of fine wire. The iron core is used to conduct magnetic lines of force efficiently.
When current flows through the primary winding, a magnetic field is created. The more time current is permitted to flow, the stronger the magnetic field becomes. When the current is turned off, the magnetic field collapses causing a high voltage to be induced in the secondary winding through the process of induction.
A few hundred volts will be generated in the primary winding because of the collapsing magnetic field across the heavy primary wire. However, as the magnetic lines of force cut across the thousands of turns of fine wire in the secondary, a far greater voltage is produced. The production of primary voltage is called self-induction, since the primary winding essentially magnifies its own initial voltage when the magnetic field collapses.
Related Symptoms
Faulty ignition system components along with loose connections, bad grounds, high resistance or opens in the circuit, may cause the following symptoms:
  • No start condition
  • Stalling after cold start
  • Stalling after hot start
  • Surging off idle
  • Extended crank time when engine is cold
  • Unstable idle
  • Running rough during off idle acceleration
  • Bucking
  • Hesitation
  • Stumble
  • Poor fuel economy
  • Spark knock
Jul 08, 2010 | 2001 Hyundai Sonata
I have just moved house to Reading and previously was able to view freeview tv using my old indoor aerial in my 2nd floor flat in london. This indoor aerial didn't pick up any signals, not even analogue,...
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
Can't get a satalite signal for tomtom XL
This can happen on rare occasions in very built up areas. Most certainly it can happen indoors.
Using tom tom home from your computer plug your device in and tell it to update. most can now accept the gpsquick fix which will allow tom toms to pick up sats a little quicker
Aug 21, 2009 | GPS
Gps model 330
-after the units have been off for awhile...they need considerable time to reconfigure the satelites
-so.....
  1. go outside with unit turned on
  2. find an open area...with a clear view of the sky...i.e. away from trees/bldgs/etc.
  3. wait...upwards of 20+ minutes...depending upon your unit
  4. it should be picking up signals continuously...and begin to calculate your location
-the above assumes that the unit has batteries, hasn't been dropped, etc.
-if that is the case....then the unit has other issues
Nov 06, 2008 | GPS
Trouble Closing
Had similar problem. Check the safety beams on both sides of the garage door opener. Check the wiring on the safety beams.
Sep 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
"Searching for Satelite" - unable to find
10-15 minutes is normal.
Did you take it outside? GPS doesn't work indoors. Try in an open field, no trees. Should lock in a few minutes. I always do the following: i key in the destination address at home, then put it under 'favourites". When i start driving, i put the unit in my car and look up the recently added favourite. The unit then has enough time to lock on to the satellites.
Jan 07, 2008 | Navman F20 GPS Receiver
InVion 4V506-IUS Portable GPS Signal issue
Thats not normal Mine takes 1 min max Even indoors.....get a new one Mine ROCKSSSSSSSSSSSSSS
Dec 01, 2007 | Garmin eTrex Legend GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
122 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
