Question about Faberware 12-55 Cup Coffee Urn
The coffee doesn't get hot enough, is there any way to adjust the theromstat
    Scholar:
  • 176 Answers
The keepwarm is not working. Go to repairshack.com. for the part. Good luck. Ron
Posted on Jul 26, 2010
Why is the coffee not hot enough
Coffee should not be hotter then 98 degrees out of the machine. I have the same problem. before I brew I fill my cup with hot water and that helped me for a hotter cup of coffee. some machines allow you to adjust temperature, eg, Krups
Dec 13, 2014 | Coffee Makers & Espresso Machines
Coffee maker
This model of coffee maker has an adjustable heating element beneath the carafe - ensure the temperature setting for the carafe is high enough to keep the coffee hot.
If the coffee is not brewing hot, the initial heating element/coil may have failed. Removal of the heating element is somewhat problematic and will require disassembly of the water container and base of the coffeemaker, and will likely need to replace the heating coil contained in a plastic sheath. Ensure you take a look at: http://home.howstuffworks.com/coffee-maker2.htm
for further detail.
Apr 07, 2014 | Cuisinart Dcc-2600 14-Cup Coffee Maker
Buick running hot
you need a thermostat or a large washer in it,s place or water will not stay in radiator long enough to cool down. you will need about an 3/4 in opening
Mar 22, 2014 | 1992 Buick Regal
Coffee is not hot enough
Put it in the microwave to get it to your desired temp!
Dec 31, 2012 | Cuisinart Grind and Brew 10 Cup Coffee...
No steam no hot water
Do you have enough water in the tank? Is the filter secured in the tank?
Move the steam dial from standby to steam and wait about 20-30 seconds, should steam if it doesn't most likely faulty.
Jun 14, 2011 | Breville Fresca BES860 2Cup Coffee Maker
How to increase temperature on model BCM120. The coffee is not hot enough after brewing. Is it possible to increase the temperature on the thermostat.
There is no temperature adjustment for the heating element under the carafe.
The Instruction Manual says:
If coffee is too cold, machine not preheated, cups not preheated, milk not heated enough (if making a cappuccino or latté)
Jun 12, 2011 | Breville Coffee Makers & Espresso Machines
My coffee is never and has never been hot. Warm at best. What can be the problem?
Hot is a relevant meaning. The temprerature of the water coming from machine should be 92oC and the coffee just out of the coffee spout should be around 82-85oC. So if the coffee is less than that the machnie have a build in scale so it can hot heat enogh or the theromstat is not working correctly and need to be replaced.
Jul 17, 2010 | Saeco Vienna De Luxe Espresso Machine
Coffee does not get hot enough
Replace the thermostat. there are alot of companies online that sell the part roughly about 20 dollars or so for the part and then about 30 minute install time
May 24, 2010 | Miele CVA615 Espresso Machine
Bunn cwtf15 coffee isn't hot enough the coffee brews @115 degrees
Adjust the thermostat, located behind the front panel, there will be a knob, turn all the way on then back about 1/4 turn.
Dec 07, 2009 | Bunn CWTF 15-TS Coffee Maker
Coffee Not Hot Enough
probably need to descale the machine scale stay on the heater and doesnt heat as much use descaler not vinegar thanks pierre
Jan 11, 2009 | Krups Small Appliances Espresso Machine
Faberware 12-55 Cup Coffee Urn Logo
Top Faberware Coffee Makers & Espresso Machines Experts
Steve
Dael Escher
Level 1 Expert
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
