Question about Toshiba TZ43V61 43" Rear Projection Television
Will not power up. Red power light only blinks.
Will not power up. Red power light only blinks. Even after disconnecting power source overnight, set will click on for couple of seconds, then red light only blinks.
    Problem Solver:
  • 17 Answers
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
Posted on May 04, 2010
Testimonial: "Did not locate "LED indication" in the manual, however thanks for input. I will continue searching."
My canon mf 3010 printer is blinking red light no working only red light blink
Unplug printer from power source. Then wait 40 seconds and plug back in. Re-set your router.
May 14, 2017 | Canon Office Equipment & Supplies
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
HAd been working fine turned it off came back later turned it on e light comes on blinks 14 times. unplugged it hoping for a reset. no.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Dec 31, 2015 | Televison & Video
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
How do I stop the anti-theft device red blinking light? Car is off and locked and from the window can see the red light blinking.
the red light drain 0.001amp. from you battery.need 1000 hour to drain 1 amp. test the battery if is any good. do drain test on the car.rust and short will drain battery overnight.after market equipment,light in the trunk or glove box, under hood light etc. disconnect the battery and install amp meter. do the drain test. your computers uses 0.2-0.4amp when sleep.anything over 0.5-.6 amp is bad. after you connect the amp meter give 1min. to turn all systems to sleep mode.Is normal the first minute to be high drain.
ones you know something is wrong disconnect the fuses one at the time and note if any changes. if the fuse you disconnect turn the amps low note what system is connected to the fuse and you will know were is the problem
Oct 24, 2014 | 2003 Oldsmobile Alero
Of 3 lights: green on right and red in center are flashing, unable to stop them.
How to fix blinking lights Printer lights blink in certain patterns to tell you about specific problems. Read this document until you see the pattern that your lights are making. The solution is below each pattern. NOTE: There may be more than one reason why the printer lights are blinking, so you may see several solutions. PRINT CARTRIDGE light RESUME light POWER light Off Off Off c00106861.jpg c00106862.jpg c00106863.jpg Problem
The printer will not turn on.
Solutions
1. Check the power cord or power module connections at both the printer and the power source (power outlet, power strip or surge protector).
2. Try disconnecting and reconnecting the power cord or power module to the printer.
3. Try reconnecting the power cord or power module to the power source or try a different power source.
4. Verify that the printer is connected to a power outlet that works.
5. Make sure there are no additional switches turned off, such as those on a power strip or surge protector.
6. Check the power breaker to make sure the power source is working.
If these solutions did not fix the problem, have the printer serviced. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09170&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=59129
Dec 09, 2010 | HP DeskJet 940c InkJet Printer
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TOSHIBA MODEL #42HP95-BLINKING RED POWER LIGHT WONT STOP
Ur power inverter board is dead.
U need a new board.
Sep 07, 2009 | Toshiba 42HP95 Television
RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
Mar 24, 2009 | Televison & Video
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Toshiba TZ43V61 43" Rear Projection Television Logo
1,718 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
