Question about Sharp Viewcam VL-Z3U Mini DV Digital Camcorder
Driver i need sub driver for camcorder sharp vl-z3u
  • 1 more comment
  • Anonymous May 24, 2008
    I am trying to capture video on the memory card is that possible?
  • exiLe123 Jun 16, 2008
    I have a Sharp Viewcam Z VL-Z3. I can only import pictures to my computer from the mini DV. I want to know how I can import videos. Do I need a driver?
  • hgaines Sep 16, 2008
    I don't have the cd rom for my sharp vl-z3u. What do I do?
Send me driver for it
Posted on May 02, 2008
Aqui esta tu respuesta, gringuito
http://members.driverguide.com/driver/detail.php?action=download&driverid=557390
Posted on May 06, 2008
2 Suggested Answers
SOURCE:
  • 565 Answers
SOURCE: driver
driver is here
rate fixya if helped
Posted on Dec 28, 2008
Cannot find a usb driver for sharp vl-z5
http://support.sharp.net.au/drivers/.
go in these site for sharp driver
Dec 28, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
My Sharp VL-Z3U show a message that says,:Unit In Safe guard Mode
I was able to reset camcorder and problem cleared up. Thanks.
Nov 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
I want to connect my viewcam VL-Z3 to my latop, but I dont have a driver to support it. Can you help?
I had this problem too.
I searched the web high and low. Even wasted 2.99 on what claimed was the driver but turned out to only be instalation directions.
From what I understand, Sharp no longer supports camcorders, so obtaining the dirver from them is out of the question.
Connecting your camcorder to your computer via USB is only used to transfer photos from your SD on your camcorder. You cannot transfer video via this method.
Here`s what I did to solve the problem of not having the driver.
I got a $10 SD card reader for my computer and this solved the problem.
To transfer video from your VL-Z3U to your computer, all you need is a firewire cable .
Assuming that you have a firewire port on your computer, simply connect your camcorder to your computer via firewire, power up your camcorder and your computer should automaticly recognize your device.
You can now transfer video to your computer using your normal video capture/editing software.
Hope this helps
Aug 07, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Driver
driver is here
Sep 08, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Mar 26, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Cameras
I took mine to an authorised repair center,but was of no help. The error generally shows due to IC problem OR the head has some issue. Do not try any DIY.
Feb 14, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
Nov 04, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
535 people viewed this question
Top Sharp Video Cameras Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
