Question about LG DLG0452W Gas Dryer
How do I get the back of a LG Dryer DLG0452W off?
How do I get the back of a LG Dryer DLG0452W off so I can check for possible motor problems because the drum will not turn ?
  • LG Master
  • 8,220 Answers
You cannot get the back off. You work from the front.
Remove the top first by getting the rear screws off then remove the controls and top front brace then remove the drum glide then the take the belt loose and lift out the drum. You will now be able to examine the motor.
Posted on May 03, 2010
Thermalfuse
It's A circuit breaker located on the out side of the burner at the 7 o'clock position. You need to remove the front panel to get to it. Unplug the dryer before doing this.
Dec 08, 2011 | LG DLG0452W Gas Dryer
I have a LG (DLG0452W) gas dryer. It will tumble, but no heat. The light bars by the timer display are flashing orange instead of green. What could be the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 27, 2011 | LG DLG0452W Gas Dryer
LG DLG0452W: Light inside the drum stays on even after closing the door tightly and dryer does not start. It flashes to check the lint tray but there isn't anything in there. HELP!!
If that light stays on I would say something definitely is wrong with the door safety lock mechanism. I have an LG dryer service manual that may help you: LG GAS& ELECTRIC DRYER repair manual
Jan 10, 2011 | LG DLG0452W Gas Dryer
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
Our DLG0452W dryer will not start occasionally, I then open the door and push in the door switch and rotate the drum and quickly close the door and 1 out 4 times it will keep running. Next time it may be...
The problem is with the centrifugal switch on the dryer motor. This switch connects the start winding of the motor which provides additional torque at startup. Once the dryer is up to speed, the switch disconnects the start winding. If it malfunctions, the dryer will not turn and the motor will hum. By spinning the drum, you are providing enough torque for the start winding to be able to take over and bring the dryer up to speed.
You may be able to correct this by simply lubricating the centrifugal switch which may be sticking. I am not sure if the centrifugal switch is replacable, or if a new motor is necessary if lubricating does not solve your problem.
Mar 14, 2010 | LG DLG0452W Gas Dryer
LG dryer DLG0452W not getting hot. (gas not turning on)
reset circuit breaker outside burner chamber, and cleaned out the unit.
Feb 24, 2010 | LG DLG0452W Gas Dryer
How to open the top of an LG gas dryer
Check question. what is the trick to getting off the front and top. (LG DLG0452W Gas Dryer)
Dec 30, 2009 | LG DLG0452W Gas Dryer
LG DLG0452W Gas Dryer Logo
570 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
