Question about Zebra TLP 2844-Z Thermal Label Printer
Scaling issues with zDesigner 2844-z
When printing from a web-page, the page scales as it should if using the universal 2844-z driver. but Using the Zebra Designer driver, it scales off the page. What would cause this?
When printing from a web-page, the width and height settings are not perssistent, every time i need to change it. Is there any way to fix it
Posted on Feb 13, 2013
  • 53 Answers
You need to set the label size in the driver. Goto printers and faxes then right click on your zebra printer driver. Left click properties and then left click the advanced tab, then left click printing defaults button and the size is listed there.
Posted on May 19, 2010
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver (1.0.0.43) but the barcode does not print using the ZDesigner driver...
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Aug 23, 2011 | Zebra TLP 2844-Z Thermal Label Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Hi, if I am printing a form, my 5L printer cannot print the full pages, it runs into two or more pages.What needs adjustment? thank you
The issue could either be in your general printer setup (adjust the scaling % in the printer options) or in the application you are printing (adjust the page setup scaling % or it may possibly have the option to print 1 page high x 1 page wide).
Feb 10, 2010 | HP LaserJet 5L Printer
The button becomes red once I print a test page
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, its the same path but one extra click. Click paper output and enter the size.
Oct 05, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Everytime I turn my Zebra TLP 2844-Z printer on,
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
Oct 01, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zud - print error - under temperature
Try using the latest zebra printer driver. The ZUD driver has been superceded by the latest Zdesigner driver which works in Zebra Designer and any windows application
Jun 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra 2844
There is specific coding you need to use to get it to work. Word documents add special characters to the batch files causing them not to printer properly.
You could try a merge to printer opertion in word and see if that will work. Make sure you to turn the printer on and off before attempting it to reset the control codes.
Jul 21, 2008 | Zebra TLP 2824 Printer
PRINT SCALING
Print scaling adjustments are in the print driver.
They are in different locations depending on the driver. PCL or PS.
But there will be a scaling adjustment within the driver in te properties.
Will have to search through the driver features to find it.
Jan 14, 2008 | Xerox Phaser 7400/DXF Laser Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
585 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
