Question about HP LaserJet 5L Printer
The printer only the test sheet
The printer prints only test sheet
  • 1 more comment
  • goldhor May 03, 2010
    the cable is good .it does not print documents it pr ints test page
    you said that you will return me my money
  • goldhor May 07, 2010
    the printer does not print a document
    it does not any thing when i want to print any thing
    the only time the printer priints when i use self test
    the printer passed self test
    it sas the LPT 1 PORT is not working
    if
    it the computer is faulty i would hot know how to correct it
  • HP Master
  • 12,061 Answers
Ok, this usually happens if A: The printer driver hasn't been installed properly, Or, B: the actual printer, hasn't been chosen and set as "Default". The first time you print, you must actually "Select" that printer from the "Print" menu...
www.hylink.com/web/LJ5L-6L%20Service%20Manual.pdf
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=15005&lang=en&cc=us&prodTypeId=18972&prodSeriesId=25480&taskId=135
Above are the links for Drivers, please download and reinstall these drivers, also get the manual, it will show you what to do, step by step.
Posted on May 07, 2010
    Sergeant:
    Novelist:
  • 172 Answers
Hello goldhor, I would need more information to help you. When you send something to print do you see it under the printer's window? (Start - Control Panel - Printer and Faxes - double click your printer). You should see the document and the status.
Is that your default printer?
Posted on May 03, 2010
  • Leonardo Garcia
    Leonardo Garcia May 04, 2010
    goldhor, you did not answer any of my questions. I didn´t say anything about the cable. If you can print the test page that means that there´s comunication between the computer and the printer. I asked If you send a document to print do you see it as a job on the printer status window?
Feel like an idiot...does the paper load with the print facing downward or upward?
You didn't say what brand and model printer you have so I can't look up a manual and check it for you. But if you don't want to waste a sheet of good stationery or a valuable form (like checks), make a test sheet. Take a plain sheet of paper and mark it along the top edge. Or use a photocopy of the form as a test sheet. Put the test sheet into the printer and print something on it. From the result you'll know how to feed the sheets in the future.
Mar 31, 2011 | Office Equipment & Supplies
HOW CAN I PRINT A TEST PAGE FOR MY KODAK ESP 5250
To print a test page:
  1. Make sure you have the latest version of firmware
2. Load8.5 x 11-in. plain inkjet paper in the paper tray. 3. Dothe following steps depending on the printer: ON ESP 3250, 5250, Office 6150 or 7250:
  1. On the control panel press Home.
  2. Select Maintenance, then press OK.
  3. Select Print Test Page, then press OK.
  4. Press Start.
  5. Wait for the test page to print.
For the 5000 Series Printers, a diagnostic sheet is usedinstead of a test page. To print a diagnostic sheet:
  1. Make sure you have the latest version of firmware. See How do I upgrade my all-in-one printer with the latest version of firmware?
  2. Load 8.5 x 11-in. plain inkjet paper in the paper tray.
  3. Do the following steps depending on the printer:
ON 5100: 1. Press and hold Quantity + Copy. ON 5300 or 5500: 1. Press the Menu button. 2. Scroll down to PrintDiagnostic Sheet. 3. Press OK. 4. Press Start. Wait for the test page to print.
Nov 20, 2010 | Kodak Office Equipment & Supplies
I have re-installed my printer. It prints, but doesn't print anything what's going on?
I think you mean it sheet-feeds but does not print. If so, power off. If network connected, power off the print server. Power all back on after a minute. Depress power button on printer for 10 seconds.
If auto test page prints, problem is with printer configuration on your computer. Check the configuration carefully. Did you uninstall with the HP Scrubber utility before you did the re-install?
In If the test sheet feeds but does not print, use the HP printer utility, check ink levels, check cartridge "expiration", and clean heads several times. Test again.
Oct 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Mar 07, 2009 | HP DeskJet 920c InkJet Printer
HP will not print.It printed the test sheet.
If it printed a test sheet, then the problem is in your program..
go to your printer and faxes folder, (same place as youfound the print test page)
set the HP printer to Default
Try to print from Word or Notepad, when the printer select window pops up make sure the HP is showing, and selected.
If you have more than one printer installed on your Computer, but only one printer, delete all the printers you are not using..
Oct 27, 2008 | Office Equipment & Supplies
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
Laser jet 5 will not print from my laptop. was fine until yesterday. now get error message. did all tests. printer printed out test sheet. computer printed out test sheet. just cannot print a document.
Looks like this is second printer installed on ur lappy... if that is so open Printers and Faxes and make ur laser jet 5 as default printer. Can give more accurate solution if u'll mention what error msg u got...
Plz Rate Me... Thanks.
May 13, 2008 | Office Equipment & Supplies
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
HP LaserJet 5L Printer Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
