Question about HP ProLiant DL580 G5 (438087-001) Server
Raid 10 can i configure across both sas trays on the DL580 G5 a raid 10 set using all 16 disks an 8 + 8
  • 506 Answers
The porn site have installed it add-on your browser. Check and see if you can see any strange program on add and remove software program window. If you can remove it but you must be sure before doing that. Alternatively, download a malware removaMicrosoft
Posted on May 29, 2010
A disk read error has occurred when booting a Dell PowerEdge 2950. Passes all diagnostics. Will run chkdsk from CD. Raid battery was degraded at last reboot but all disks showed to be fine. Raid 1
what OS?
what disk?
no raid card stated, no array stated, no type of array stated.
One can put 100s of RAID cards in this server.
both raid cards or HBA cards,(forJBOD)
i can fix any server, but first need to know what is in the box first
you meant the boot disk has errors, right,? boot.
that would tell me the disk IS BAD.
but if and ARRAY , that means you must run SMART tests
on the disks, 1 by 1 to find the bad disk.
if smart shows its bad, or weak its for sure BAD.
on real servers. the server sends you email, (set up right)
telling you disk 3 in a RAID 6 is bad, replace it now.
are you running hardware or software raid, or HBA or
fake raid cards, (4 classes there.!)
the base system new has.
4 port SAS 5/i integrated SAS controller (no RAID_
and optional, from DELL , news.
Optional PERC 5/i integrated SAS/SATA daughtercard controller with 256MB cache,
PERC 4e/DC, PERC 5/e adapter
or any of 1000s of other aftermarket cards there.
I run LSI 9361s (with MSM appl loaded)
this card will tell you what disk failed every time no kidding.
so will the PERCs setup correctly
the PERCs and my LSI and my HP raids
all have installed monitors for the RAID ,a program that runs full time all the time, and reports errors , many ways,
did you load that first and use it? seems not.
as no mention of SMART at all.
good luck.
Im not sure the names on DELL , MSM like software.
ah its OSA
never run a PERC lacking this APP. or you can not keep the server on line,.
http://www.dell.com/support/search/us/en/04#q=Dell%20OpenManage%20Server%20Administrator&sort=relevancy&f:langFacet=[en]
Mar 05, 2018 | Dell Computers & Internet
Recently I had replaced one of HDD of my DL580 service Raid 5 configuration. After that everything working fine including user connectivity and database access. My question is both the LEDs on replace
After you replaced the drive, did you rebuild the RAID array? Some of the higher end RAID controllers will try to rebuild automatically (if set to do so) but most must be rebuilt manually.
Dec 22, 2014 | HP ProLiant DL580 G5 (438087-001) Server
How to save a raid0 disk
Raid O is no RAID. Data is lost if the hard drive failed. Always use RAID 1 (mirrored) for OS and RAID 5 (striped) for DATA. That's 5 drives your server should shave been configured with.
Jul 16, 2012 | HP Compaq ProLiant ML350 G5 Server
How do I make RAID 1 HDD's appear on Bootable USB WinXP Install?
a waste of time and effort installing win xp on anything as it is no longer supported by Microsoft and had real problems with drivers for just about everything
install win 10 and it will work
Feb 28, 2018 | Dell POWEREDGE 1950 Server
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
Performed a clean installation of windows xp sp2 which I purchased and the installation won't complete it says error 1 cannot boot from drive how to fix this ?
you need a raid controler then use a raid driver disk before install windows, because you use sas as primary disk. these disk is for unix and server blade server, using sometimes windows server as Op System.
is a tradicional steps when using special hard disk
Aug 08, 2010 | IBM (40K1042) 36 GB SAS Hard Drive
I got a Dell Precision 690 in which I have 2 SAS hard drives of 300gb and OS is XP 64Bit.This Disks are connected in HD0& HD1. When I tried ti reinstall XP 64, setup load the file and when start the...
if your hard drives were in a RAID configuration at any point or your computer has a RAID controller in it nothing will work until you reconfigure the RAID setup. it is probably a good idea at this point to completely wipe the drives as there may be some lingering RAID configuration data remnants on them and this can also mess things up pretty good.
Feb 25, 2010 | Dell Precision Workstation 690 - 750W...
HP ProLiant DL580 G5 (438087-001) Server Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
