Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
Just got a Ryobi brush cutter, but no instructions. What is the gas mixture in english please. Thanks
    Sniper:
  • 52 Answers
Use 4 ounces of 2 cycle oil in one gallon of gas.
Posted on May 04, 2010
Testimonial: "Thanks, a lot! I didn't want to ruin it with the wrong mixture. Your answer was prompt and clear!"
    Sniper:
  • 56 Answers
Ryobi recommends a 50:1 mixture 2.6 0oz oil to 1 gal of gas...it will run on 32:1 mixture that djcarmon recommends, but you will have a lot more fuel and oil related problems (gumming of carb, stopped up arrestor screens in muffler, and generally messy I have found). I run only premium gas (93 or better octane) and either optimoil or pennzoil 2 cycle oil with great results at a ratio of 45:1... 2.8oz of oil to 1 gal gas...with a little Stabil fuel stabilizer thrown in for good measure....very few if any carb problems ( I clean and check my carb every spring before start up) and good engine life...run my ol' Ryobi for five years now and other than replacing fuel filters once a year (which I do religiously as maintenance)and an occaisional fuel line have had very few problems...takes a lickin' and keeps on tickin'...to each his own...but this works for me !!! hope this helps.
Posted on Jul 03, 2010
What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Oct 03, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
I want to check if a makita rbc 230 brush wood cutter runs on petrol (neat) or two stroke mixture
I think the model your speaking of is the RBC30. It is a 2 stroke mixture. The 430 models are 4 stroke and do not require mixing oil and fuel. They are made by Ryobi for Makita.
Here is the RBC 30
RBC30SESA
  • Powerful 30cc 2-Stroke Petrol Engine
  • Easy-Start Carburettor
  • Expand-It™ Attachments Compatible
  • 18"/46cm Cutting Path Width
  • 2 Year Domestic Warranty
Info on the 430
RYRBC430SES
  • New 4 Stroke Design
  • Light in Weight 7.3kg
  • Safe Anti-kick Feature
  • Reduced Noise Levels, Lower Emissions
  • 2 Year Warranty
This is pretty much the entire line up of their brush cutters:
http://www.mowdirect.co.uk/acatalog/MowDIRECT_RYOBI_BRUSHCUTTERS___PETROL_STRIMMERS_311.html
There is not a 230 model.
Thanks for choosing FixYa.
Kelly
Sep 06, 2010 | Garden
Hi,My Ryobi 30 Petrol with Brush Cutter attachment has so much vibration I cant use it..
This is likely a mechanical problem caused by either 1. A serious imbalance with the cutter attatched to it 2. The engine is failing and the main crankshaft bearings are worn causing crankshaft "wobble" setting up the heavy vibration you speak of.
Aug 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have no spark on my Ryobi Brush Cutter. Replaced spark plug but still no spark.
If the spark plug you have put in has the correct gap then u will next have to check or change the HT lead Change it if no spark is showing
Apr 20, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Nov 30, 2009 | Ryobi Garden
BAD STARTER
it might have a easy start that wound make it seem like its sliping.change spark plug and gap at 030.see if it helps if not rebuild carb.
good luck
Jul 20, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Need a manual for a RYOBI Model RY30530.
go to www.managemyhome.com and download a free copy of the manual.
Jun 26, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
401 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
